array of function pointers
Electrofabio
PostPosted: Wed May 04, 2011 9:01 am     Reply with quote
Hi everybody,
I'm having issues with the implementation of an array of function pointers.
I'm using PIC 18F47J53, with 4.114 compiler.
The firmware I'm using is the following:
#include <18F47J53.h>
#include <usb_bootloader.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES PLL5                     //Divide By 5(20MHz oscillator input)
#FUSES PLLEN
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOCPUDIV
#FUSES HSPLL                    //External Clock with PLL enabled and Fosc/4 on RA6
#FUSES SOSC_HIGH
#FUSES CLOCKOUT
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES DSWDTOSC_INT
#FUSES RTCOSC_T1
#FUSES DSBOR
#FUSES DSWDT
#FUSES DSWDT2147483648
//#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES ADC10
#FUSES MSSPMSK7
#FUSES WPFP
#FUSES NOWPCFG
#FUSES WPDIS
#FUSES WPBEG
#FUSES LS48MHZ
#use delay (clock=48000000)
typedef void (*pointer)();              //function pointer definition
pointer parse_function[10];            //array of function pointer definition
void fun_001();
void fun_002();
void fun_003();
void fun_004();
void fun_005();
void fun_006();
void fun_007();
void fun_008();
void fun_009();
void fun_010();
     parse_function[0] = fun_001;
     parse_function[1] = fun_002;
     parse_function[2] = fun_003;
     parse_function[3] = fun_004;
     parse_function[4] = fun_005;
     parse_function[5] = fun_006;
     parse_function[6] = fun_007;
     parse_function[7] = fun_008;
     parse_function[8] = fun_009;
     parse_function[9] = fun_010;
     while (true)
        output_high(pin_D2);
        output_high(pin_D4);
        output_low(pin_D2);
        output_low(pin_D4);
        (*parse_function[0])();
        (*parse_function[1])();
        (*parse_function[2])();
        (*parse_function[3])();
        (*parse_function[4])();
        (*parse_function[5])();
        (*parse_function[6])();
        (*parse_function[7])();
        (*parse_function[8])();
void fun_001()
   output_low(pin_D2);
   output_low(pin_D4);
void fun_002()
   output_high(pin_D3);
   output_high(pin_D5);
   output_low(pin_D3);
   output_low(pin_D5);
void fun_003()
   output_low(pin_D3);
   output_low(pin_D5);
void fun_004()
   output_low(pin_D3);
   output_low(pin_D5);
void fun_005()
   delay_ms(200);
   output_low(pin_D3);
   output_low(pin_D5);
   delay_ms(200);
void fun_006()
   delay_ms(300);
   output_low(pin_D3);
   output_low(pin_D5);
   delay_ms(300);
void fun_007()
   delay_ms(700);
   output_low(pin_D3);
   output_low(pin_D5);
   delay_ms(700);
void fun_008()
   delay_ms(800);
   output_low(pin_D3);
   output_low(pin_D5);
   delay_ms(800);
void fun_009()
   output_low(pin_D2);
   output_low(pin_D4);
void fun_010()
(the code inside fun_001 ... fun_010 is just a debugging example)
When I try to run the program, the PIC restarts at the moment of the call to the first function, continuosly;
Do you have any experience with function pointers? is there any error in the code?
I made a lot of test with different configurations; now I'm wondering about a bug in the compiler or even a problem due to my specific hardware.
Thanks.
PostPosted: Wed May 04, 2011 11:38 am     Reply with quote
I the problem is due to that particular PIC. There may be a bug with the
compiler code for it. I modified your program to use an 18F452 and it
ran OK in the MPLAB simulator (MPLAB vs. 8.66). But with the 18F47J53
it got "Out of Bounds memory access" errors.
I don't have time this morning to try to figure out the problem in the ASM
code. It's possible that some work-around could be devised, but I don't
have time right now.
I tested this with vs. 4.121. It didn't work with that one so I didn't bother
trying it with vs. 4.114.
Electrofabio
PostPosted: Wed May 04, 2011 3:37 pm     Reply with quote
Thanks for now Smile
I'll be waiting for a confirmation about this bug.
future
PostPosted: Wed May 04, 2011 5:32 pm     Reply with quote
I would not waste time trying to use function pointers with ccs. Build a switch() with one case for each function you want, wrap it in a function and call it with the number you want.
The compiler will create a jump table with good speed and no bugs.
