hi
I am using PIC18F2525 USART to send a character and string via Rs232 to Hyperterminal....I am using a 4MHz crystal oscillator, i am able to display the characters on the screen only at 250000 baud rate with every character repeating itself
meaning
my Output needs to be
D
dimple
bhuta
my current output is
DDddiimmppllee
bbhhuuttaa
I have included my code, any advice would be very appreciated
Thank you
void puts(far rom char *Str )
do
unsigned char c;
c = *Str;
putc (c);
if (*Str==13) putc (10);
if (*Str == 10) putc(13);
Str++;
} while ((*Str) != 0 );
void main (void)
TRISC =0b10000000;
USART_setup ();
putc('D');
puts ("dimple\n");
puts("bhutadc\n");
Posted: Mon May 02, 2011 1:26 pm
You're using the Microchip C18 compiler, but you're posting on the CCS
compiler forum. They're not compatible. Here is the C18 forum:
http://www.microchip.com/forums/f3.aspx
