SPI two way communication problem
neohimura
PostPosted: Fri Apr 22, 2011 11:51 am     Reply with quote
I'm trying to do two way communication between a master and a slave using SPI. I succeeded in doing one way communication for example sending data from master to slave or sending data from slave to master separately. When I try to send and receive data from one slave I'm getting the wrong data. Below is one of the way I tried to do this. I also tried putting spi_write and spi_read in sequence but it didn't work. Can anyone please help me. Thank you.
MASTER
setup_spi(spi_master|spi_l_to_h|SPI_CLK_DIV_16);
      output_low(slave3_select);
      delay_us(100);
         spi_write(joystick_data[0]);
         spi_write(joystick_data[1]);
         spi_write(joystick_data[2]);
         spi_write(joystick_data[3]);
         motor1_speed=spi_read(joystick_data[4]);
         motor2_speed=spi_read(joystick_data[5]);
         motor3_speed=spi_read(joystick_data[6]);
         motor4_speed=spi_read(joystick_data[7]);
      output_high(slave3_select);
      delay_us(100);
SLAVE
setup_spi(spi_slave|spi_l_to_h);
       if(input(slave3_select) == 0)
         spiheader=spi_read();
            spidata[0]=spi_read();
            spidata[1]=spi_read();
            spidata[2]=spi_read();
            spidata[3]=spi_read(current_ccp_delta1);
            spidata[4]=spi_read(current_ccp_delta2);
            spidata[5]=spi_read(current_ccp_delta3);
            spidata[6]=spi_read(current_ccp_delta4);
         delay_cycles(1);
PostPosted: Fri Apr 22, 2011 12:57 pm     Reply with quote
Look at these SPI slave examples and try to do it in a similar way:
http://www.ccsinfo.com/forum/viewtopic.php?t=39145
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
neohimura
PostPosted: Fri Apr 22, 2011 9:53 pm     Reply with quote
Examples you gave used the SPI interrupt. Is it possible to do it without using the interrupt?
Thank you.
PostPosted: Fri Apr 22, 2011 10:06 pm     Reply with quote
See this CCS example file:
c:\program files\picc\examples\ex_spi_slave.c
neohimura
PostPosted: Mon Apr 25, 2011 6:20 am     Reply with quote
When I tried the above code with two pic18f4550, it works.. but when I change the slave pic into dspic30f4011, the data becomes corrupted. I can only receive data from the master. When I try to send data to master, it doesn't work.. Is there any setting i need to change in dspic30?
Thank you.
PostPosted: Mon Apr 25, 2011 12:45 pm     Reply with quote
I don't have the PCD compiler, so there is no way I can test it.
PostPosted: Tue Apr 26, 2011 2:56 pm     Reply with quote
Have a look at this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=41421&highlight=dspic+spi>
