Baerle1983
Return Value different to content of Variable ? |
Posted: Sat May 25, 2013 12:38 pm |
Hello Everyone,
i have a function to read from the SPI:
Code: | char *edip_read(void)
{ char result[10];
int i=0;
edip_SendC(0x00);
do
output_bit(edip_ss,0);
result[i] = spi_read2(0);
output_bit(edip_ss,1);
i++;
}while(!input(Pin_B0));
#ifdef debug
printf("EDIP_Read:%s",result);
return result;
which is called from my isr with:
Printf("Int Result:%s",edip_read());
The written results from the 2 printf´s differ in the first 2 Characters, the 3rd to 9th are equal.
Can anyone tell me what i´m doing wrong ? |
asmboy
Posted: Sat May 25, 2013 2:54 pm |
it is i very risky and not good practice to do serial IO
from inside an ISR
instead use flags to semaphore "data ready"
and do the printf from main() or one of its child functions. |
hmmpic
Posted: Sun May 26, 2013 6:24 am |
Define the return array as static in your function. |
