How to use 'break' jump out of 3 nested loop?
cchappyboy
PostPosted: Wed Jun 01, 2011 9:28 am     Reply with quote
Hi
I want to use 'break' jump out of loops. The code in below.
while(condition1)
   while(condition2)
      while(condition3)
           if(condition)
      }//loop3
         dosomething3();
    }//loop2
         dosomething2();
}//loop1
dosomething1();
So after break is happened, which line is going to be executed.
Thanks.
PostPosted: Wed Jun 01, 2011 9:34 am     Reply with quote
'break', always exits the innermost loop only.
What will be executed, will depend on what condition2, and condiftion1 evaluate to.
Normal method:
int1 exit=FALSE;
while(condition1 && (exit==FALSE))
   while(condition2 && (exit==FALSE))
      while(condition3 && (exit==FALSE))
           if(condition)
               exit=TRUE;
      }//loop3
         dosomething3();
    }//loop2
         dosomething2();
}//loop1
dosomething1();
This way you can design your code to exit as many levels as you want.
PostPosted: Wed Jun 01, 2011 12:27 pm     Reply with quote
If you don't apply for a good coding style award, you'll notice, that a simple goto will save both text lines and code space. Smile
