fattahtafreshi
4094 Shift Register 3 wire LCD - Driver By (Fattah-Tafreshi) |
Posted: Mon Apr 18, 2011 8:34 am |
//main.c
//Fattah-Tafreshi
//fattah.roland@gmail.com
//2011
//4094 LCD Serial
#include "main.h"
//4094 PINs
#define data PIN_B0
#define clock PIN_B1
#define Strobe PIN_B2
#include "f_lcd.c"
int i;
for(i=0;i<=15;i++)
lcd_gotoxy(i,1);
lcd_putc('-');
lcd_gotoxy(16-i,2);
lcd_putc('-');
printf(LCD_PUTC,"\fwww.ir-micro.com\n");
printf(LCD_PUTC,"4094 Serial LCD");
delay_ms(2000);
printf(LCD_PUTC,"\fFattah-Tafreshi\n");
printf(LCD_PUTC,"VAF-O-T 2011");
//main.h
#include <16F84A.h>
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use delay(clock=16000000)
//outshift.c
//Fattah-Tafreshi
//2011
//4094(Shift Register) 3wire Serial To Parallel
byte d0,d1,d2,d3,d4,d5,d6,d7;
#IFNDEF data
#define data PIN_A0
#define clock PIN_A1
#define strobe PIN_A2
#ENDIF
//4094 Shift Register
void set_shift(int8 value)
int8 location=0,n=0;
location=128;
for(n=1;n<=8;n++){
if ((value & location)>0) output_bit(data,1); else output_bit(data, 0);
output_bit(clock,1);
location=location / 2;
output_bit(clock,0);
output_bit(strobe,1);
output_bit(strobe,0);
void f_output(byte value)
set_shift(value);
void fatport()
int value;
value=0;
if (d0==1) value=value+1;
if (d1==1) value=value+2;
if (d2==1) value=value+4;
if (d3==1) value=value+8;
if (d4==1) value=value+16;
if (d5==1) value=value+32;
if (d6==1) value=value+64;
if (d7==1) value=value+128;
f_output(value);
void dg0(int value)
d0=value;
fatport();
void dg1(int value)
d1=value;
fatport();
void dg2(int value)
d2=value;
fatport();
void dg3(int value)
d3=value;
fatport();
void dg4(int value)
d4=value;
fatport();
void dg5(int value)
d5=value;
fatport();
void dg6(int value)
d6=value;
fatport();
void dg7(int value)
d7=value;
fatport();
void f_output_bit(byte pin,value)
switch(pin)
case 1:dg0(value);
case 2:dg1(value);
case 3:dg2(value);
case 4:dg3(value);
case 5:dg4(value);
case 6:dg5(value);
case 7:dg6(value);
case 8:dg7(value);
void f_output_high(byte pin)
switch(pin)
case 1:dg0(1);
case 2:dg1(1);
case 3:dg2(1);
case 4:dg3(1);
case 5:dg4(1);
case 6:dg5(1);
case 7:dg6(1);
case 8:dg7(1);
void f_output_low(byte pin)
switch(pin)
case 1:dg0(0);
case 2:dg1(0);
case 3:dg2(0);
case 4:dg3(0);
case 5:dg4(0);
case 6:dg5(0);
case 7:dg6(0);
case 8:dg7(0);
//flcd.c
//Fattah-Tafreshi
//2011
//Edit flex_lcd For 4094(Shift Register) Serial LCD
#include "outshift.c"
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
#define LCD_DB4 5
#define LCD_DB5 6
#define LCD_DB6 7
#define LCD_DB7 8
#define LCD_E 4
#define LCD_RS 3
//#define LCD_RW -->> GND
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
f_output_bit(LCD_DB4, !!(nibble & 1));
f_output_bit(LCD_DB5, !!(nibble & 2));
f_output_bit(LCD_DB6, !!(nibble & 4));
f_output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
f_output_high(LCD_E);
delay_us(2);
f_output_low(LCD_E);
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
f_output_low(LCD_RS);
delay_us(60);
if(address)
f_output_high(LCD_RS);
delay_cycles(1);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]);
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
address = lcd_line_two;
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
lcd_send_byte(0,0x10);
default:
lcd_send_byte(1,c);
Last edited by fattahtafreshi on Wed Apr 20, 2011 7:05 am; edited 2 times in total |
Wayne_
Posted: Mon Apr 18, 2011 8:36 am |
So errrr, whats wrong with it ? |
fattahtafreshi
Wayne_
Posted: Mon Apr 18, 2011 8:53 am |
You expect me to download that zip file? Why?
it would be nice if you actually asked a question and explained why you posted this.
If it is, as I expect a driver you have written which you wish to distribute then it should have been posted in the code section, not here. |
Joined: 01 Jul 2010 Posts: 9134 Location: Greensville,Ontario
Posted: Mon Apr 18, 2011 9:57 am |
What's 'wrong', is that I can buy a PIC cheaper than the 4094 !
Using the PIC, I can have a 'smart' LCD, offloading the main PIC all of the 'driver' functions.
Sign of the times..... |
fattahtafreshi
fattahtafreshi
New Version |
Posted: Tue Aug 20, 2013 6:02 am |
//main.c
//Fattah-Tafreshi
//2011-2013
//4094 LCD Serial
#include "main.h"
//4094 PINs
#define SR4094_data PIN_B0
#define SR4094_clock PIN_B1
#define SR4094_Strobe PIN_B2
#include "f_lcd.c"
int i;
int n=0;
for(i=0;i<=15;i++)
lcd_gotoxy(i,1);
lcd_putc('-');
lcd_gotoxy(16-i,2);
lcd_putc('-');
printf(lcd_putc,"\fwww.ccsinfo.com\n");
printf(lcd_putc,"4094 Serial LCD");
delay_ms(2000);
printf(lcd_putc,"\fFattah-Tafreshi\n");
printf(lcd_putc,"VAF-O-T 2013");
delay_ms(2000);
while(true)
lcd_gotoxy(1,1);
printf(lcd_putc,"\f%u",n);
n++;
//main.h
#include <16F84A.h>
//f_lcd.c
//Fattah-Tafreshi
//2011-2013
// flex_lcd.c
#define LCD_DB4 4
#define LCD_DB5 5
#define LCD_DB6 6
#define LCD_DB7 7
#define LCD_E 3
#define LCD_RS 2
0xc, // Display on
1, // Clear display
delay_cycles(1);
delay_us(2);
delay_us(60);
if(address)
delay_cycles(1);
void lcd_init(void)
int8 i;
delay_ms(15);
delay_ms(5);
int8 address;
if(y != 1)
address=0;
address += x-1;
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
default:
lcd_send_byte(1,c);
//outshift.c
//Fattah-Tafreshi
//2011-2013
#IFNDEF SR4094_data
#define SR4094_data PIN_A0
#define SR4094_clock PIN_A1
#define SR4094_strobe PIN_A2
#ENDIF
unsigned char tempdata=0;
void set_shift(unsigned char value)
unsigned char mask=0x80;
do{
if(value & mask) output_bit(SR4094_data,1);else output_bit(SR4094_data,0);
output_bit(SR4094_clock,1);
output_bit(SR4094_clock,0);
mask>>=1;
}while(mask);
output_bit(SR4094_strobe,1);
output_bit(SR4094_strobe,0);
void f_output_bit(unsigned char pin,short value)
if(value == 1)
tempdata|=(1<<(pin % 8));
tempdata&=~(1<<(pin % 8));
set_shift(tempdata);
void f_output_high(unsigned char pin)
void f_output_low(unsigned char pin)
Nascimento
Posted: Wed Dec 30, 2015 7:16 pm |
hi friend simulated in Proteus all right
more when I made the card did not work |
Nascimento
Posted: Wed Dec 30, 2015 7:17 pm |
you could send the layout of the 4094 card?
ps: google translator |
