I Can't enable PLLEN on PIC18F87J50 [solved]
E_Blue
PostPosted: Thu Apr 14, 2011 9:00 am     Reply with quote
The main OSC is an 8MHz crystal, and I'm debugging with an ICD3 debugger.
#include <18F67J50.h>
#fuses HS,PLL2,CPUDIV2,NOIESO,NOFCMEN,STVREN,CCP2E7,NOWDT,NOPROTECT
#use delay(clock=48M)
#BYTE OSCTUNE = 0xF9B
#BIT PLLEN=OSCTUNE.6
void Main (void)
    OSCTUNE=0x40;
        output_toggle(PowerLed);
Did I forgot something? Question
Electric Blue
E_Blue
PostPosted: Thu Apr 14, 2011 11:49 am     Reply with quote
Solved, the fuse must be H4_SW instead HS.
H4_SW generates confusion, at least for me, because nowhere does not say anything about the PLL.
Anyway thanks!
Electric Blue
