I2C SET MULTI_MASTER
david91184
PostPosted: Sun Apr 10, 2011 2:39 am     Reply with quote
I have to do is to use four dsPIC33 the value to an EEPROM using I2C transmission problems, I now hit me that the signal will be searched on the site also tried to sample a lot of information occur collision would like to ask the network signal Of you help me
#include <33FJ64MC802.h>
#fuses HS,NOWDT,NODEBUG,NOWRTSS,NOPROTECT ,PR_PLL,ALTI2C
#use delay (clock=80M, crystal=10M)
#pin_select U1TX = PIN_B4
#pin_select U1RX = PIN_B5
#use rs232(UART1,baud=115200,parity=N,bits=8)
#bit U1STA_UTXEN = 0x223.2
#use i2c(multi_master, scl=PIN_B8, sda=PIN_B9)
char cmd;
int  flag=0;
int16 data_a0=0,data_a1=0,data_read=0,x=0,POS1CNT=0,y=0;
/*void init_ext_eeprom()
   output_float(PIN_B8);
   output_float(PIN_B9);
void write()
     int status;
     int state;
     do
         output_high(pin_a0);
         i2c_start();
         state=i2c_write(0xa0);
         if(state==0)
             if(y!=POS1CNT)
                i2c_start();
                i2c_write(0xa0);
                i2c_write(0x01>>8);
                i2c_write(0x01);
                i2c_write(POS1CNT>>8);
                i2c_stop();
                i2c_start();
                status=i2c_write(0xa0);
                while(status==1)
                   i2c_start();
                i2c_stop();
                i2c_start();
                i2c_write(0xa0);
                i2c_write(0x02>>8);
                i2c_write(0x02);
                i2c_write(POS1CNT);
                i2c_stop();
                i2c_start();
                while(status==1)
                   i2c_start();
                i2c_stop();
                y=POS1CNT;
         if(state==1)   i2c_stop();
         output_low(pin_a0);
     }while(state!=0);
int read1()
   int state;
   do
      i2c_start();
      if(state==0)
         i2c_start();
         i2c_write(0xa0);
         i2c_write(0x01>>8);
         i2c_write(0x01);
         i2c_start();
         i2c_write(0xa1);
         data_a0=i2c_read(0);
         i2c_stop();
         i2c_start();
         i2c_write(0xa0);
         i2c_write(0x02>>8);
         i2c_write(0x02);
         i2c_start();
         i2c_write(0xa1);
         data_a1=i2c_read(0);
         i2c_stop();
         data_read=(data_a0<<8)+data_a1;
   }while(state!=0);
   return data_read;
#int_RDA
void  RDA_isr()
    cmd = getchar();
    switch(cmd)
        case 'S':
                 U1STA_UTXEN = 1;
        case 'E':
                 U1STA_UTXEN = 0;
        case 'Q':
                 flag=1;
        case 'W':
                 flag=0;
#INT_TIMER1
void  TIMER1_isr( )
   set_timer1(65535-125);
   x++;
   if(x == 100)
      x=0;
      write();
void main (void)
    enable_interrupts(INT_RDA);
    enable_interrupts (INTR_GLOBAL);
    setup_timer1(TMR_INTERNAL|TMR_DIV_BY_8);
    U1STA_UTXEN = 0;
    //init_ext_eeprom();
    POS1CNT=read1();
    while (1)
         output_high(pin_b15);
         if(flag==1)
            printf("\r\nPOS1CNT:%d",POS1CNT++);
