circular buffer and adc
alimary158
PostPosted: Sun Jan 29, 2012 2:49 am     Reply with quote
Good morning,
I have wrote this code to read adc values from a sensor and using a circular buffer i want to write them on sd! I have managed to make the code working but it seems I'm missing something since when i make this code run i manage to write on sd just for the length of the buffer and nothing more.
Instead i would like to keep on acquiring variables till there is power off
so what am i doing wrong?
int16 data=85;
#define RxADCQsize 64
volatile int16   RxBaseADC[RxADCQsize];
// Rx Ring Buffer control
volatile BYTE   RxHeadADC;
BYTE   RxTailADC;
#INT_timer2
void timer2_isr()
 //data=read_adc(); //This function will read the digital value from the ADC
   RxBaseADC[RxHeadADC++]=data;
   // test if ring buffer wrap is required
   if (RxHeadADC >= RxADCQsize)
      RxHeadADC = 0;
void main (){
    FIL fsrc;            // file structures
    FRESULT result;     // FatFs function common result code
    WORD btw, bw;       // File R/W count
    FRESULT   FS_Status;
    char pressure[16];
    int16 value;
    disable_interrupts(GLOBAL);
    restart_wdt();
   // Pic Inizialization
   init_pic();
  // setup_adc_ports(sAN1);
   //setup_adc(ADC_CLOCK_INTERNAL);
   //set_adc_channel(1);
   setup_timer_2 (T2_DIV_BY_16,255,6);
   RxHeadADC=0;
   RxTailADC=0;
   clear_interrupt(INT_RDA);
   enable_interrupts(INT_RDA);
   enable_interrupts(int_timer2);
    do
      FS_Status = f_mountdrv();
   while (FS_Status);
   //Il file creato si chiamera pressure.txt
   strcpy(pressure,"adc.txt");
   //F_OPEN(): if the file already exist the datas will be appened. if the file doesnt exsist it is created
   result=f_open(&fsrc,&pressure,FA_OPEN_ALWAYS | FA_WRITE);
   result=f_lseek(&fsrc,fsrc.fsize);
   //write a string delimiter to each append data log
    strcpy(pressure,"hello");
    btw=strlen(pressure);
    result=f_write(&fsrc,pressure,btw,&bw);
   int  i=0;
   for(i=0;i<70;i++){
         disable_interrupts(int_timer2);
         //while
         if(RxHeadADC != RxTailADC)
            // here we have data waiting to be written
            sprintf(pressure,"Valore=%lu\r\n",RxBaseADC[RxTailADC++]);
            if (RxTailADC >= RxADCQsize)
               RxTailADC=0;
            result=f_write(&fsrc,pressure,strlen(pressure),&bw);
   f_close(&fsrc);
In particular in this code i would like to use the adc in the interrupt timer2 and read the values there and put them in the buffer. I know i should have a infinite loop somewhere and i tried now to make a loop with a for() to check if i can actually lets say write 70 samples on the file. But it seems I am not able and I'm just outputting 30 samples.
Anyone can help? Thanks
PostPosted: Sun Jan 29, 2012 11:35 am     Reply with quote
This is not a complete program, unknown PIC type, compiler version,etc.
Odds are real good you're trying to use a 5volt PIC with an SD card...never going to work unless you have logic level convertor chips in the circuit( will need to see your schematic).
Have NO idea what 'driver' is being used for the SD card access...
You say you want to use interrupts ,yet you disable them in main()...
I suggest you delete everything and start over..
Create a simple program that loops for say 255 times to store data to the sdcard. If you save it in CSV format, any PC will be able to read the data and you can confirm that it is correct.This program might take 15-20 lines of code.
PostPosted: Mon Jan 30, 2012 9:43 pm     Reply with quote
int i=0;
for(i=0;i<70;i++){
Declaration of variables in the middle of code is not allowed in CCS.
Put all variable declarations at the beginning of each function.
