ccp1 using timer1
newpic
ccp1 using timer1
PostPosted: Mon Apr 04, 2011 1:37 pm     Reply with quote
I need capture help.
How can I capture a button that connect to CCP1 (RC2)?
if button pressed < 500msec === output high pin RB0
if button pressed > 500 msec === output high pin RB1
#include <p18f4620.h>
#include <delays.h>
#include <usart.h>
#include <stdio.h>
#define CapRise 0b00000101;
#define CapFall 0b00000100;
#define printf(a) printf((rom far char *)a)
unsigned int T1 = 0;
unsigned int T2 = 0;
unsigned int Width = 0;
void isr_high(void);
void isr_low (void);
void init(void);
#pragma idata
volatile unsigned char port_value = 0;
#pragma code
   TMR1H = 0x00;
   TMR1L = 0x00;
   init();
   while(1) // continuous loop
// interrupt setup
#pragma code high_vector=0x08
void high_vector (void)
   _asm GOTO isr_high _endasm
#pragma code low_vector=0x18
void low_vector (void)
   _asm GOTO isr_low _endasm
#pragma code
#pragma interrupt isr_high
void isr_high (void)
   T1CON = 0b00000101;    // 1:1 prescale, osc off, no synch, int clk, tmr1 on
   T1 = CCPR1;
   PIR1bits.CCP1IF = 0;   // clear capture flag bit
   CCP1CON = CapFall;
   while(!PIR1bits.CCP1IF);
   T2 = CCPR1;
   Width = (T2-T1);
   if(Width < 500)
      PORTBbits.RB0 = 1;
                   PORTBbits.RB1 = 0;
                   PORTBbits.RB0 = 0;
                   PORTBbits.RB1 = 1;
delay_ms(50);
printf("Pulse width =%d cycles\r\n",Width);
#pragma interruptlow isr_low
void isr_low(void)
   // unused
void init(void)
   // USART Setup
   OpenUSART (USART_TX_INT_OFF &
         USART_RX_INT_OFF &
         USART_ASYNCH_MODE &
         USART_EIGHT_BIT &
         USART_CONT_RX &
         USART_BRGH_HIGH, 25); // 9600 bps @ 4MHz
   // hardware setup
   ADCON1 = 0b00001111; // A/D disabled
   TRISC = 0x04;        // RC2 CCP1 pin = input
   PORTB = 0;           // clear portb on POR
   TRISB = 0;           // all outputs
   PORTA = 0;
   TRISA = 0;
   CCP1CON = CapRise;   // capture on rising edge
   // interrupt setup
   IPR1bits.CCP1IP = 1;   // CCP1 int is high priority
   PIE1bits.CCP1IE = 1;   // enable CCP1 interrupt
   RCONbits.IPEN = 1;     // enable priority levels on interrupts
   INTCON = 0b11000000;   // global & peripheral ints enabled
PostPosted: Mon Apr 04, 2011 1:45 pm     Reply with quote
You're using the Microchip C18 compiler. You're in the wrong forum.
This is the CCS compiler forum. You want the C18 forum, here:
http://www.microchip.com/forums/f3.aspx
newpic
timer1
PostPosted: Mon Apr 04, 2011 2:12 pm     Reply with quote
Ok,
I post the wrong code,
here it is
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F452.h>
long rise,fall,pulse_width;
#int_ccp2
void isr()
   rise = CCP_1;
   fall = CCP_2;
   pulse_width = fall - rise;     // CCP_1 is the time the pulse went high
                                  // CCP_2 is the time the pulse went low
                                  // pulse_width/(clock/4) is the time
                                  // In order for this to work the ISR
                                  // overhead must be less than the
                                  // low time.  For this program the
                                  // overhead is 45 instructions.  The
                                  // low time must then be at least
                                  // 9 us.
  if(pulse_with > 500)
      output_high(PIN_B0);
      output_low(PIN_B1);
     output_high(PIN_B1);
      output_low(PIN_B0);
   delay_ms(50);
   printf("\n\rHigh time (sampled every second):\n\r");
   setup_ccp1(CCP_CAPTURE_RE);    // Configure CCP1 to capture rise
   setup_ccp2(CCP_CAPTURE_FE);    // Configure CCP2 to capture fall
   setup_timer_1(T1_INTERNAL);    // Start timer 1
   enable_interrupts(INT_CCP2);   // Setup interrupt on falling edge
   while(TRUE) {
      printf("\r%lu us ", pulse_width/5 );
what do I divide pulse_width to in order to get the ms or sec instead of us?
I do not understand where do we get the /5 from? This is one of the example came with CCS compiler.
PostPosted: Mon Apr 04, 2011 2:23 pm     Reply with quote
The 20 MHz clock is divided by 4 to get the instruction clock. That's in
every PIC data sheet. Timer1 is clocked by the instruction clock.
So it's clocked at 5 MHz. It's counting in units of 1/5 of a microsecond.
If you get 5 counts, then it took 5us to do that. They want to display
the output in units of microseconds, so they divide the count by 5.
If you want to display in units of milli-seconds, then divide it by 5000
instead of 5. But you'll need to cast 'pulse_width' to a float, to get the
correct result from the math. And change the printf to "%7.3f" or
something similar.
