Regarding saving data to EXT EEPROM
jaikumar
PostPosted: Sat Apr 02, 2011 12:13 am     Reply with quote
Hi All,
I want to save stream of data which are in groups of 144 bytes.
I am using 24C512 eeprom. This has a page boundary of 128 bytes.
How can I split this data, so I can save to eeprom using page write.
Any help/Ideas would be great?
Thanks & Regards,
Jai.
PostPosted: Sat Apr 02, 2011 7:06 am     Reply with quote
one way...
You could setup a circular buffer of 160 bytes, every write to eeprom would save the first 128 bytes of the 144 of the msg to a page. The 'last' 16 bytes would be stored (in front of ) with the first 112 of the next msg. Obviously you have to keep track of the msg 'number' vs. the eeprom 'page'.
Not all that hard to do, just write it down on graph paper to see how it works. It's a 'trick' I've done for the past 30 years to NOT waste memory space.
PostPosted: Sat Apr 02, 2011 10:11 am     Reply with quote
Or of course, depending on available RAM, and how often data needs to be written, realise that 8 messages=9 EEPROM pages. Have an 8 message buffer in the chip, and write 9 pages when this fills.
