gadylio
pic16f877a through rs232 using max232, garbage is out |
Posted: Tue Mar 29, 2011 2:31 pm |
my code is
#include <16F877A.h>
#FUSES XT, NOWDT, NOPROTECT
#USE DELAY(CLOCK = 4000000)
//Hardware UART : TX is RC6, RX is RC7
#USE RS232(baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
//Define inline functions: isupper() and islower()
//isAmong(): checks if the character is in the character list, if so return true else false.
char temp[20];
char x[20];
strcpy(temp, "kitchen"); // Copy const string into ram array
// Now you can use strcmp() to compare temp to another array.
// Put your strcmp() code here.
output_high(pin_b7);
output_low(pin_b7);
delay_ms(2000);
printf("kitchen\n");//
delay_ms(2000);
printf("bath\n");
delay_ms(2000);
printf("gad5ra\n");
delay_ms(2000);
printf("2skot\n");
gets(x); //getc() is used for receiving one character from PC.
if(strcmp(temp,x))
delay_ms(2000);
Posted: Tue Mar 29, 2011 3:29 pm |
delay_ms(2000);
strcmp() returns 0 if the strings match. So, if string 'x' matches string
'temp', the code above will NOT execute. Pin B7 will not go high. |
