Hi
How can i define int24 variable ? (with structure or another way) . I mean the 23th bit of this variable must be the sign bit !
Posted: Sun Mar 27, 2011 1:41 pm
Why do you need a 'signed int24' ? Why can't you use a 'signed int32' ?
Where does the signed 24-bit data come from ? Is it from an A/D chip ?
Does it come in by SPI ?
ROBOTICAR
Posted: Sun Mar 27, 2011 2:11 pm
yes. It's from AD chip and comes in by spi. I used 'signed int32' for that and i know we must use this type. But i think there is a way that we can make signed int24. My friend said you can use :
typedef struct _byte
unsigned int a : 8;
unsigned int b : 8;
unsigned int c : 8;
} int24;
int24 *K;
I think it isn't a good way ...
Is there any way for make it ?
By the way I'm searching about ways for making unusual types.
another question. Is there way for making 64-bit variables in 8-bit structure pic microcontroller ?
