USB application with 18f4550 is not enumerating.
dnz_1905
PostPosted: Thu Mar 31, 2011 9:50 am     Reply with quote
Firstly, I would like to thank all the contributors and moderators of "ccsinfo.com/forum" for this great website.
I am a beginner at USB communication and I want to make a simple led application with 18f4550. But I can not make it work. When I plug the USB cable, I can not get any response from the computer. Its not loading the driver.
My aim is:
When the USB cable connected, LED1(yellow) on
When its enumerated, LED2(green) on,
else LED3(red) on.
I am using 20 Mhz Crystal oscillator with two 15pf capacitors. I use the B2 pin for connection sense and I use VUSB pin with 470nF.
Here is the code, that I wrote:
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN
#use delay (clock=48000000)
#DEFINE USB_HID_DEVICE  true
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE    255  //allocate 8 bytes in the hardware for transmission
//the following defines needed for the CCS USB PIC driver to enable the RX endpoint 1
// and allocate buffer space on the peripheral
#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_RX_SIZE    255  //allocate 8 bytes in the hardware for reception
#include <pic18_usb.h>
#include <USB.H>
#include <usb_desc_hid.h>
#include <usb.c>
#define USB_CON_SENSE_PIN PIN_B2
#define usb_attached() input(USB_CON_SENSE_PIN)
#use fast_io(d)
int8 x;
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
   // TODO: USER CODE!!
   set_tris_d(0x00);
   output_d(0x00);
   usb_init();
   x=0;
     usb_task();
      if(usb_attached() && usb_enumerated())
        output_d(0x01);
     else if(usb_attached() && !usb_enumerated())
        output_d(0x04);
     else if(!usb_attached())
        output_d(0x02);
Please help me.Crying or Very sad
PostPosted: Thu Mar 31, 2011 11:43 am     Reply with quote
Try it by using the CCS example file, ex_usb_hid.c.
This thread explains all the little changes that need to do, to make it
work with your hardware:
http://www.ccsinfo.com/forum/viewtopic.php?t=38897
