Loop problem
xman_di
Loop problem
PostPosted: Thu Mar 24, 2011 8:33 am     Reply with quote
I have a PIC18F6585 in use for many things. With the following code, the read works fine. If I try to make it a for loop (in comments), it doesn't work. What is up?
#INT_TIMER1
void adc_interrupt (void) //setup interrupt
 int16 i;
 i = 15;
 adc_value = 0;
 output_low(ADC_convert);             //ADC track and hold on falling edge
while(input(ADC_busy)){}               //wait for conversion complete
 output_high(ADC_convert);
 for(i=15;i>=0;i--){
    output_high(ADC_clock);
    output_low(ADC_clock);
    if(input(ADC_data))
       bit_set(adc_value,i);
    if(input(ADC_data))
        bit_set(adc_value,15);
        bit_clear(adc_value,15);
    if(input(ADC_data))
       bit_set(adc_value,14);
        bit_clear(adc_value,14);
    if(input(ADC_data))
       bit_set(adc_value,13);
        bit_clear(adc_value,13);
    if(input(ADC_data))
       bit_set(adc_value,12);
        bit_clear(adc_value,12);
    if(input(ADC_data))
       bit_set(adc_value,11);
        bit_clear(adc_value,11);
    if(input(ADC_data))
       bit_set(adc_value,10);
        bit_clear(adc_value,10);
    if(input(ADC_data))
       bit_set(adc_value,9);
        bit_clear(adc_value,9);
    if(input(ADC_data))
       bit_set(adc_value,8);
        bit_clear(adc_value,8);
    if(input(ADC_data))
       bit_set(adc_value,7);
        bit_clear(adc_value,7);
    if(input(ADC_data))
       bit_set(adc_value,6);
        bit_clear(adc_value,6);
    if(input(ADC_data))
       bit_set(adc_value,5);
        bit_clear(adc_value,5);
    if(input(ADC_data))
       bit_set(adc_value,4);
        bit_clear(adc_value,4);
    if(input(ADC_data))
       bit_set(adc_value,3);
        bit_clear(adc_value,3);
    if(input(ADC_data))
       bit_set(adc_value,2);
        bit_clear(adc_value,2);
    if(input(ADC_data))
       bit_set(adc_value,1);
        bit_clear(adc_value,1);
    if(input(ADC_data))
       bit_set(adc_value,0);
        bit_clear(adc_value,0);
newguy
PostPosted: Thu Mar 24, 2011 9:11 am     Reply with quote
Change
int16 i;
to
signed int16 i;
and it will work. int16's are unsigned by default, so your loop's test (is i >= 0?) will always be true.
xman_di
PostPosted: Thu Mar 24, 2011 9:25 am     Reply with quote
Thanks! Works great now! Very Happy
