MAX517 DAC
oanguloc
MAX517 DAC
PostPosted: Mon Jul 02, 2012 12:39 pm     Reply with quote
I'm trying to make a DAC using a MAX517 with PIC18F6622. Could somebody provide me with a working code?
ezflyr
PostPosted: Mon Jul 02, 2012 3:19 pm     Reply with quote
Setup your I2C communications like this:
#define MAX517_SCL PIN_A0      // Serial Clock signal to the MAX517
#define MAX517_SDA PIN_A1      // Serial Data signal to the MAX51
//-----< I2C Port Definition >-----
#use i2c(master, sda=MAX517_SDA, scl=MAX517_SCL, FAST)
Use whatever I/O pins you want, and be sure to use appropriate pull-up resistors on the SCL ans SDA lines. 4.7K works well.
and send data to the MAX517 like this:
write_dac(128); //set D/A to 2.5V
Here is the subroutine that controls the MAX517:
// This routine receives a byte from Main, and sends it out to the MAX517
// D-to-A converter. The range of the input is 0 to 255, which corresponds
// to an output voltage of 0 to 5V.
void write_dac(int data_out)
    i2c_start();
    i2c_write(0x58);          // Device address when AD0 and AD1 are tied to ground
    i2c_write(0);
    i2c_write(data_out);      // Send the data to the device
    i2c_stop();
Good Luck!
John
oanguloc
PostPosted: Mon Jul 02, 2012 3:54 pm     Reply with quote
Thank you very, John. It is nice found people like you.
