problem with #FUSES CCP2E7
goranst
PostPosted: Sun Mar 13, 2011 5:29 pm     Reply with quote
Hello everybody,
I am using CCS 4.065 and having difficulties with setting PIN_E7 as ECCP2 pwm pin on PIC18F87J50.
As I have seen on the forum, the setting should be as simple as adding #fuses CCP2E7 in the code, but this does not work.
I am using the plugin for MPLAB (MPLAB version 8.20), and every time I recompile it sets the CONFIG3H to 0xFF instead of 0xFE!
This happens even if I chose to manually set the configuration bits! Every time I press Build, MPLAB automatically changes my configuration bit.
Does anyone know how to solve this problem?
Goran Stojanovski
www.atronika.com
PostPosted: Mon Mar 14, 2011 11:38 am     Reply with quote
I got the same result. I'm not sure what to do about it, except to set the
correct fuses manually in the config window for your programmer.
If you have the full IDE version of the compiler, it's possible that you
can use the Device Editor to modify the fuses. This screenshot (click
to enlarge) shows the fuses can be modified in the upper right corner
of the Device Editor window:
http://www.ccsinfo.com/content.php?page=ideoverview#device
goranst
PostPosted: Mon Mar 14, 2011 6:17 pm     Reply with quote
Thank you very much for the answer.
I did what you have suggested and now everything works fine.
By the way, what is the official way for pointing out a bug to CCS? This is a obvious one because the fuses CCP2C1 and CCP2E7 had the same mask and the same value! That is way the compiler could not never set the E7 as CCP2 pwm output.
Goran Stojanovski
www.atronika.com
PostPosted: Mon Mar 14, 2011 6:59 pm     Reply with quote
Your compiler version (4.065) is over 3 years old. The latest version
(4.119) doesn't have the problem, as shown below:
CCP2 on pin E7:
#include <18F87J50.h>
#fuses HS,NOWDT,CCP2E7
Configuration Fuses:
   Word  1: F7AE   NOWDT PLL1 STVREN NOXINST NODEBUG NOCPUDIV NOPROTECT
   Word  2: FFC4   HS FCMEN IESO WDT32768
   Word  3: FEF8   EASHFT MCU BW16 NOWAIT CCP2E7 ECCPE PMPEMB MSSPMSK7
CCP2 on pin C1:
#fuses HS,NOWDT,CCP2C1
   Word  3: FFF8   EASHFT MCU BW16 NOWAIT CCP2C1 ECCPE PMPEMB MSSPMSK7
