Proteus run incorrect with SPI between 2 PIC18, help me !
iVoVa
PostPosted: Mon Mar 14, 2011 1:17 pm     Reply with quote
#include<18F4520.h>
#use FAST_IO(D)
   int number;
   setup_spi(SPI_MASTER );
      number = input_D();
      spi_write(number);
#include<18F4520.h>
#use FAST_IO( D)
   int8 num;
   setup_spi(SPI_SLAVE );
      num = spi_read();
      output_D(num);
PORTD of Slaver do not change when I change input to MASTER and it run incorrect.
Please help me. Thanks a lot.
PostPosted: Mon Mar 14, 2011 2:22 pm     Reply with quote
hmmm... you're using fast_io() but where's your setup of the tris registers ?
Have you disabled other peripherals you don't use ?
Do you need a chip select for the slave ?
Your hardware for switch and LED is incomplete.
active high, active low ?
iVoVa
PostPosted: Tue Mar 15, 2011 3:55 am     Reply with quote
Thanks temtronic so much, i have solved problem, pin SS must be connected GND.
