Data logger
sdbleed
Data logger
PostPosted: Mon Feb 28, 2011 8:28 pm     Reply with quote
Hello good morning my friends.=D
I would like to ask for guidance on how I can use the fat.c and mmcsd.c as part of a data logger. What are the steps to follow in order to make a data logger?
I would like to store temperature data on sd card continously.
Thank you very much.
I am using a pic18f2520 and ccs c 4.114.
sdbleed
PostPosted: Mon Feb 28, 2011 8:54 pm     Reply with quote
fatopen(char *name, char *mode, FILE *fstream)                  ////
////  Opens up a FILE stream to a specified file with the specified  ////
////  permission mode:                                               ////
////             Permissions: "r" = read                             ////
////                          "w" = write                            ////
////                          "a" = append                           ////
////                          "rb" = read binarily                   ////
////             "w" will erase all of the data in the file upon     ////
////              the opening of the file.                           ////
////             "a" will tack on all of the data to the end of the  ////
////              file.                                              ////
////             "r" will keep on reading until the stream           ////
////              hits an '\0'                                       ////
////             "rb" will keep on reading until the amount of       ////
////              bytes read equals the size of the file.
Unlike standard C fopen(), this does not malloc a FILE -       ////
////  instead the caller will have to have allready allocated a      ////
////  a FILE and pass a pointer to it.
Can someone please provide an example on how to use this?
What does it mean to allocate a file and pass a pointer to it?
andrewg
PostPosted: Tue Mar 01, 2011 7:33 am     Reply with quote
sdbleed wrote:
Can someone please provide an example on how to use this? (fatopen)
It means you have a variable like:
FILE myfile;
Then call:
fatopen("filename.txt", "r", &myfile);
Have a look in your Examples folder for "ex_fat.c".
Andrew
sdbleed
PostPosted: Tue Mar 01, 2011 6:09 pm     Reply with quote
I'll take a look at the example.
Will post again if I have further questions.
Thanks! Very Happy Very Happy Very Happy
Is this correct?
char myfile[]="first.txt";
O do I have to assign a pointer?
char *myfile[]="first.txt";
