capacitive sensing using PIC16f727
kbruin79
PostPosted: Thu Feb 24, 2011 1:33 am     Reply with quote
I am using compiler PCW 4.105. I couldn't get the built in capsense functions to work. I had no errors but LED0 AND 1 simply won't light up to a capsense input. Any idea if i am missing anything? Thanks
#include <16F727.h>
#include <math.h>
#include <stdlib.h>
#include <float.h>
//#include <stdarg.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOMCLR,VCAP_A6
#use delay (internal=4000000) //(clock=4M)
#use fast_io (A)              // use the manual way for assigning IO pins
#define CLR 12
#use touchpad(scantime=32ms,threshold=6,PIN_B0='C',PIN_B1='D',PIN_B2='E',PIN_B3='F')
// Main
set_tris_a(0xf0);
setup_adc_ports(NO_ANALOGS);
//Set PORT A Output to GND
output_low(PIN_A0);
output_low(PIN_A1);
output_low(PIN_A2);
output_low(PIN_A3);
//Set PORT E Output to GND
output_low(PIN_E0);
output_low(PIN_E1);
output_low(PIN_E2);
   //main loop
   char c;
      TOUCHPAD_STATE(1); //calibrates, then enters normal state
      if(touchpad_hit())
         c=touchpad_getc();
      If (c=='C')
      //TURN ON LED0
       output_low(PIN_A0);
       output_high(PIN_A1);
       output_high(PIN_A2);
      if (c=='D')
      //TURN ON LED1
       output_high(PIN_A0);
       output_low(PIN_A1);
       output_low(PIN_A2);
newguy
Re: capacitive sensing using PIC16f727
PostPosted: Thu Feb 24, 2011 8:13 am     Reply with quote
kbruin79 wrote:
// Main
set_tris_a(0xf0);
output_low(PIN_A0);
output_low(PIN_A1);
output_low(PIN_A2);
output_low(PIN_A3);
output_low(PIN_E0);
output_low(PIN_E1);
output_low(PIN_E2);
//main loop
char c;
if(touchpad_hit())
c=touchpad_getc();
If (c=='C')
//TURN ON LED0
output_low(PIN_A0);
if (c=='D')
//TURN ON LED1
output_low(PIN_A1);
output_low(PIN_A2);
My guess is that you'll want to move the highlighted line OUT of the main loop of your program. Calibrate the touch sensor just before your while(TRUE) loop. With it where it is, the system will attempt to calibrate "out" finger touches.
bkamen
PostPosted: Thu Feb 24, 2011 10:17 pm     Reply with quote
Or, maybe call it every 10,000 (or some number) passes.
kbruin79
PostPosted: Wed Mar 02, 2011 1:11 am     Reply with quote
Thank you newguy. I followed your suggestions and I got it to work.
