LCD display value no response??
haowhaow
PostPosted: Mon Feb 07, 2011 10:09 pm     Reply with quote
I'm newbie in programming. I'm using pic18f4520 and 16 x 2 lcd.
After simulation is ok, but in real device, my lcd is blank.
I don't know how to configure my code. Can anyone here help me to solve it ?
Here is my code:
#include <18F4520.H>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#device ADC=10         //10-bit conversion
#use delay(clock = 20000000)
#include "lcd.c"
   float temp, lsb;
   int8   msd, lsd;
   lsb = 5000.0/1024.0;               //lsb in mv
   lcd_init();                        //initialize lcd
   while(1)                        //do forever
      setup_adc(ADC_CLOCK_INTERNAL);      //ADC clock source
      setup_adc_ports(ALL_ANALOG);      //ADC inputs
      set_adc_channel(0);               //select RA0
      temp = read_adc();               //get temperature
      /*convert reading to temperature*/
      temp = temp*lsb;            //temp in mv
      temp = temp/10.0;            //temp in degree C
      msd = temp;                  //msd digit
      lsd = 10.0*(temp-msd);         //lsd digit
      printf(lcd_putc,"\fTemp.: %U.%U C", msd,lsd);
tmsenthil03
PostPosted: Mon Feb 28, 2011 8:04 pm     Reply with quote
please mention above two lines are in the main loop not in the while loop...
And also check the LCD interface port what they have mention in the LCD.C header file
M.Senthilkumar
