Prolem with SPI frame Sync mode on PIC24FJ128GA010 #inc
geolover
PostPosted: Wed Mar 16, 2011 5:52 pm     Reply with quote
Hello everyone!
I'm trying to initialise a spi interface as frame sync master and spi master(i.e, outputting both frame sync pulse and free-running serial clock). However, my problem is that although I'm getting data on SDO pin and clockage on SCLK pin, there is no frame sync-pulse appear whatsoever, I'm using ccs compiler v4.117:
Here is my code:
#include <24FJ128GA010.h>
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PR                       //Primary Oscillator
#FUSES CKSNOFSM                 //Clock Switching is enabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES XT
#bit frmen2 = 0x0264.15
#bit spifsd2= 0x0264.14
#bit spifpol2=0x0264.13
#bit spife2 = 0x0264.1
//#bit msten2 = 0x0262.2
#bit cke2   = 0x0262.8
#bit ckp2   = 0x0262.6
#use delay(clock=8000000)
#use rs232(UART1,baud=9600,parity=N,bits=8)
      int8 i;
      frmen2 = 1; //frame enable
//      msten2  =1;
      spifsd2 =0; //frame sync output
      spifpol2=0;//frame sync polarity is active high
      spife2  =1;//frame sync pulse coincide with spi data
//      cke2    =0;
//      ckp2    =1;
   setup_spi(SPI_MASTER | SPI_CLK_DIV_4);
   //setup_spi2(SPI_SS_DISABLED);
   setup_spi2(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4);//set spi 2 to master mode, cke=0, ckp=1, clock frequency is 8MHz divided by 4
   for (i=0;i<256;i++)
      spi_write2(0xFFFF);
      delay_us(10);
      spi_write2(0xFF);
      delay_us(10);
//   setup_wdt(WDT_ON);
//  setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   // TODO: USER CODE!!
