problem with pointers
cerr
PostPosted: Thu Feb 17, 2011 1:14 pm     Reply with quote
Hi There,
I think I'm running into some kind of problems with my pointers... Surprised
I defined a
typedef struct {
  int16 value;
  char id;
} eevalues;
and then an array of these values like this:
eevalues store[VARNUM]
and I pass it to a function as a eevalues *data pointer but in the function i can't access the values anymore :( I only get 0s trying to access it like this:
data[0]->value
- how come? Evil or Very Mad
jacqueskleynhans
PostPosted: Thu Feb 17, 2011 2:43 pm     Reply with quote
These forums are valuable resources have a look around and also try searching for your problem elements.
http://www.ccsinfo.com/forum/viewtopic.php?t=44697&highlight=struct
This might not help but it contains some struct examples. Also I found a google search with maybe something like struct and pointer with CCS. usually narrows a search better than using ccs search.
Best of luck
Jacques
"THE ONLY EASY DAY WAS YESTERDAY"
bkamen
Re: problem with pointers
PostPosted: Thu Feb 17, 2011 2:59 pm     Reply with quote
cerr wrote:
Hi There,
I defined a
typedef struct {
  int16 value;
  char id;
} eevalues;
data[0]->value
Did you try data[0].value ??
I do this stuff all the time...
And if you look in the K&R C programming Lanuage , you'll see that your use of '->' is incorrect as -> is used when the pointed structure is a pointer... which you don't have up there.
Check page 128-131 of K&R's "The C Programming Language" for more verbose usage to help you along.
-Ben
cerr
PostPosted: Thu Feb 17, 2011 5:03 pm     Reply with quote
Exactly right, -> is used to dereference (it's the same as (*XYZ)) and i had a brain fart there and didn't realize that. But why would the code compile at all? I would ixpect it to throw an error like value is not an element of data* or similar...
bkamen
PostPosted: Thu Feb 17, 2011 5:04 pm     Reply with quote
(shrug)
Cheers,
-Ben
