delay
cerr
delay
PostPosted: Wed Feb 16, 2011 1:36 pm     Reply with quote
I'm very new to using CCS and in fact this is my first day utilizing it.
I loaded the led flash application but it seems like my delay is 10 times to slow e.g. 100ms delay is giving me in fact a 1second pulse...
I do use a 10MHz crystal (the one that comes on the PIC18 explorer board from Microchip).
I don't understand as I'm not using any kind of prescaler or something.
The code:
#include <18F8722.h>
#device ICD=TRUE
#device adc=16
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES LP                       //Low power osc < 200 khz
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=10000000)
#define LED PIN_D0
#define DELAY 100
   setup_timer_4(T4_DISABLED,0,1);
    //Example blinking LED program
    while(true){
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
Thanks for hints! Rolling Eyes
PostPosted: Wed Feb 16, 2011 1:43 pm     Reply with quote
Look in the PIC data sheet, in the oscillator section, to see the correct
fuse setting for a 10 MHz crystal.
cerr
PostPosted: Wed Feb 16, 2011 1:59 pm     Reply with quote
Exactly, that did the trick,
Thank you bud, for that hint!
