Zachr
18f23k22, using internal clock, timing issue |
Posted: Sun Feb 13, 2011 11:33 am |
This is the first time I have used a 'K' family of pic. Trying to do a hello-world blink and LED. If I download the following:
#include <18F23K22.h>
#device adc=16
#FUSES INTRC //Internal RC Osc
#FUSES NOPLLEN
#FUSES WDT_NOSLEEP
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#use delay(int=16000000)
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
output_high(pin_c0);
output_low(pin_c0);
and run it, C0 stays high. If I run the same code, but start it from the debugger, I get C0 toggling once a second like it should. If I reduce the delay from 1000ms down to 100ms, it works with or without the debugger. If I do this:
output_low(pin_c0);
...it fails unless started in the debugger. Seems like a clock config issue, but nothing I try seems to make a difference. Thoughts? Suggestions?
Thanks,
Zach |
Zachr
Posted: Sun Feb 13, 2011 1:18 pm |
Should have mentioned using I'm using 4.119
-Zach |
Posted: Sun Feb 13, 2011 2:18 pm |
Try a more simple program:
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=16M)
output_high(PIN_C0);
output_low(PIN_C0);
I tested this in hardware for an 18F45K22 and it worked. I ran it in
standalone (not debugger) mode. This was with vs. 4.119. |
Zachr
Posted: Sun Feb 13, 2011 2:34 pm |
Thanks! That helped me figure it out. The issue is that the even though I was using the NOWDT fuse, if the WDT128 fuse is in there, the watchdog starts up.
The PIC wizard adds the WDT128 fuse even if you say you don't want to use the watchdog timer. Seems to be a bug. |
