jacqueskleynhans
Joined: 10 Apr 2008 Posts: 109 Location: Cape Town, South Africa
TI RI-R6C RFID |
Posted: Thu Feb 10, 2011 2:45 am |
HI Guys, I need to interface this RFID to a PIC 18f4550 : http://focus.ti.com/lit/ug/scbu030/scbu030.pdf
Its a +-14Mhz transceiver IC from TI.
This HF Transceiver is using a weird or more politically correct (a communication protocol that's unknown to me).
Page 11 of the data sheet form link above
Quote: | The Transceiver IC can handle different RF protocols as follows:
Tag-it protocol.
ISO / IEC 15693-2 [2].
ISO / IEC 14443-2 (Type A). |
So my first question does anyone have experience with this protocol ? if so is there any sample available.
Kind Regards
Jacques _________________ "THE ONLY EASY DAY WAS YESTERDAY" |
jacqueskleynhans
Nearly there |
Posted: Thu Feb 10, 2011 3:16 pm |
Hi Ok I managed to bit bang my way through the protocol but I have encountered a problem...
Can someone please check in the data sheet I linked on pg 27 under protocol definitions fig 4.4 what the data= to be sent to TAG function is ...
S'il vous plait
Thx _________________ "THE ONLY EASY DAY WAS YESTERDAY" |
Joined: 01 Jul 2010 Posts: 9169 Location: Greensville,Ontario
Posted: Thu Feb 10, 2011 3:33 pm |
A quick look at the datasheet and I read it that
the 'command' bits configure the chip for one of several protocols and the next series of bits is the actual data to be transmitted to the RF receiver.
Unlike most UART communications of a fixed data length( 1 byte or 8 bits), this chip allows data to be variable in length.
Once the stop bit is seen, the 'tag' data is sent using the 'protocol' at the head of that datastream or packet.
Very versatile as it allows several 'layers of security', different 'protocol' and 'messages' (data) would make a system with this device very hard to break into !
Kind of a swiss army knife 'Ultimate UART' as every transmission could have a different protocol and msg length.
at least that's the way I read it.. |
