Output Compare - dsPIC
pitufos
PostPosted: Mon Feb 07, 2011 7:09 am     Reply with quote
Hi everyone,
I'm trying to work with dsPIC30F3012 running at 20Mhz(HS2_PLL8) and Output Compare module.
I'm generating pulses between 800KHz and 2MHz using OC1.
  //TIMER-PULSE MODE
  setup_timer2(TMR_INTERNAL | TMR_32_BIT  , 11);//11 to 800KHz or 4 to 2MHz
   //CONTINUOUS PULSE MODE
   setup_compare( 1,COMPARE_CONT_PULSE | COMPARE_TIMER2 );
What is the best way to "count" the pulses generated by this module?
I´ve tried to control by #int_OC1, but it didn't work.
Regards,
Leandro
