Control Relay by SMS specific Command!!!
shan
PostPosted: Sat Apr 28, 2007 7:47 pm     Reply with quote
hello Friends,
I have just joined this forum and i have gone through the fourm and i found very much helpful and i hope i can get more information and help what i am looking for. I am new here and in the the PIC programming. I need help. I want to control a RELAY simply ON / OFF when the SMS receive with specific command.
Thanks in advance.
Shan
SherpaDoug
PostPosted: Mon Apr 30, 2007 8:24 am     Reply with quote
Since no one else has replied I will ask the obvious question: What is a "SMS"? Are you asking about software or how to connect a relay to a PIC pin?
jecottrell
PostPosted: Mon Apr 30, 2007 8:39 am     Reply with quote
Short Message Service.....
http://en.wikipedia.org/wiki/Short_message_service
Connect MODEM to PIC, receive the SMS on the PIC, if it matches the condition for switching the relay, drive a PIC pin high or low, whatever's required to drive the relay.... (btw, you've got to take care of all the power and other peripheral stuff too.....)
John
PostPosted: Mon Apr 30, 2007 9:06 am     Reply with quote
SMS = text message in a GSM telephone / modem.
Which GSM modem are you using?
I'm asking this because for a Wavecom modem you would use the command AT+CMGR to read a SMS text message, but for other modem brands it is possible you have to use another command.
Search this forum for 'CMGR' and you will find some example code that can be used as a starting point.
clatita
PostPosted: Thu Feb 03, 2011 1:50 pm     Reply with quote
Hello, well I did a similar project it's just that i used an atmel microcontroller ... the idea should be the same though and i am sure you'll get some useful info about communicating with a mobile phone/gsm modem ... have a look:
http://ma-projects.blogspot.com/2011/01/project-no-1-sms-controlled-relay.html
Gabriel
PostPosted: Fri Feb 04, 2011 6:42 am     Reply with quote
hi,
I posted this code a while a go:
http://www.ccsinfo.com/forum/viewtopic.php?t=42527
It toggles 4 LEDs on and off via SMS...
You can use relays instead of LEDs and get what you want. You will have to use a driver or transistor for the relay coil as the PIC may not be able to drive it.
The code, like I say on my post is not perfect but it does work.
I however, do not know your hardware configuration and you might need to do some changes to the code.
I hope my code serves as a starting point...
g
CCS PCM 5.078 & CCS PCH 5.093
