pad
methods to calculate harmonics from voltage and current |
Posted: Mon Jan 31, 2011 10:15 am |
hi all,
I am working on a project where I need to show total harmonics distortion of voltage and current signal.
Currently I am taking 32 adc samples of voltage and current in a cycle(20 ms) of 50Hz system and calculate rms values of V & I with almost 2% accuracy. Now I need to calculate V-THD & I-THD from this signals.
I have two choices. 1] - using hardware ie by making LPF of opamp (50 Hz)and calculate rms value of this fundamental wave. At same time another adc will read and calculate unfiltered signal and this is with harmonics.
So (unfiltered - filtered) will give me harmonics content. Is this correct?
and another way 2] Digital filtering - this can also be useful but I have very small knowledge about it. If anybody will help me on this topic,will surely go for it as it requires more software and math and less hardware change. And also can calculate individual harmonic using this.
So Friends, need your help and opinion on this topic.
regards
PAD |
dyeatman
Posted: Mon Jan 31, 2011 11:08 am |
How will this relate to CCS and the PIC? What PIC are you planning to use? _________________ Google and Forum Search are some of your best tools!!!! |
pad
Posted: Mon Jan 31, 2011 11:34 am |
Quote: | How will this relate to CCS and the PIC? What PIC are you planning to use? |
Friend, is PIC & CCS is must? I think I have asked generic question on digital/analog filter which required straight forward answer, irrespective of controller and compiler.
But for your KA, I am using PIC18F6722 and CCS4.020.
I do not require any code. I am going to write that for myself. I just require help on digital/analog filter and how it will useful in my project.
If have any experience on digital/analog filter or THD, please share. |
dyeatman
Posted: Mon Jan 31, 2011 11:43 am |
This is a CCS C forum and CCS C and PIC are required by the forum
otherwise the moderator will likely lock the thread as being off topic.
Version 4.020 is a very old and buggy version and will likely give you lots of
problems if you try to use to use it. In addition, it will take quite a bit of
horsepower to perform the kind of analysis you are describing so I would
expect you would need a PIC24 or PIC 30 minimum. _________________ Google and Forum Search are some of your best tools!!!! |
SherpaDoug
Posted: Mon Jan 31, 2011 2:19 pm |
It sounds like you need to do a FFT of your data. That will give you the amplitude and phase of each harmonic. If you can live with an update rate of 1 reading/second or so I think any reasonable PIC should handle it. You do want to update your compiler though. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Mon Jan 31, 2011 2:34 pm |
I agree, that a 16-Bit PIC would be fine. But nothing has been said about real-time capability, so even complex signal processing, e.g. by FFT would be basically possible with a PIC18. Classically, THD is measured with band stop filters rather than by subtracting power of RMS and fundamental. But an FFT power spectrum (magnitude only) is an interesting option. Taking only 32 samples per period may be a bit low to measure the total harmonic content. |
pad
Posted: Wed Feb 02, 2011 8:49 am |
thanks for reply dear FvM & Sherpadog.
I am thinking that once I can find THD of V or I,though slow updated at start( once in a sec.)but will be my first step towards the goal.After that I ca definitely speed up it by higher end controller.
I am trying FFT so that I can remove 50Hz signal samples from input and will compare funda.V & I values with PQ meter.If accuracy is <=5% ,it will absolutely OK for me.
I am searching forums and google for same and have some useful data. mostly code is in assembly for fast calculations.I am new to ASM for PIC but studying it.
So friends,looking forward for your valuable suggestions and help on FFT.
PAD |
Posted: Wed Feb 02, 2011 9:47 am |
Have a look at:
<http://www.ee.washington.edu/class/472/peckol/code/FFT/brent_fft/>
Not much except changing types to suits CCS, needed.
