How to enable Phase Locked Loop module in dsPic30F4011 ?
small_chick
PostPosted: Fri Nov 02, 2012 9:48 am     Reply with quote
when i don't use this instruction "#fuses XT,NOWDT" and try to config directly through registers as the following function:
void Oscillator_Config()
        /*Oscillator Switching Sequence*/
   OSCCONH = 0x78;
   OSCCONH = 0x9A;
   OSCCONH = 0x03;
   OSCCONL = 0x46;
   OSCCONL = 0x57;
   OSCCONH = 0x01;
   while(OSWEN);
   /*Oscillator Mode is XT w/PLL 4x*/
   FOS1 = 1;
   FOS0 = 1;
   FPR3 = 0;
   FPR2 = 1;
   FPR1 = 1;
   FPR0 = 0;
   /*enable LP Oscillator*/
   LPOSCEN = 1;
   /*Oscillator Postscaler Selection = 1:1*/
   POST1 = 0;
   POST0 = 0;
   /*POR:Power-on reset timer's delay = 64 ms*/
   FPWRT1 = 1;
   FPWRT0 = 1;
   /*BOR:Minimum supply voltage = 4.2 (V)*/
   ORV1 = 0;
   ORV0 = 1;
   /*Disable Watchdog Timer*/
   FWDTEN = 0;
   SWDTEN = 0;
There's no clock for timer1 which is configurated as following:
void timers_init()
   /*initialize Timer1*/
   /*internal clock FOSC/4*/
   T1_TCS = 0;
   T1_TGATE = 0;
   PR1 = 0xFFFF;
   TMR1 = 0;
   /*Prescaler option = 1:256*/
   T1_TCKPS1 = 1;
   T1_TCKPS0 = 1;
and
void interrupt_init()
   /*enable Timer1 interrupt*/
   T1IE = 1;
   /*force Timer1 interrupt */
   T1IF = 1;
#include    <30F4011.h>
#include    "IO_module.c"
#include    "Interrupt_module.c"
#include   "Device_Configuration.c"
#include   "TimerX_module.c"
#fuses XT,NOWDT
#INT_TIMER1 NOCLEAR
void Timer1_ISR()
   T1IF = 0;
   T1_TON = 1;
   RB0 ^= 1;
   Oscillator_Config();
   port_init();
   timers_init();
   interrupt_init();
void port_init()
   /*PORTB*/
   TRISB &= ~BIT0;
   PORTB = 0xFFFF;
   ADPCFG = 0xFFFF;//config all ANx as digital
Hoping someone can help me solve this problem ? Very Happy
