Search text from a string?
glenjoy
PostPosted: Sun Jan 16, 2011 7:20 am     Reply with quote
If I have a string say, *string="jdslkajdsldjsladjABCDEFkjdfsljdsalk" and I want to check if ABCDEF do exists in that string, what is the best algorithm to use?
PostPosted: Sun Jan 16, 2011 7:40 am     Reply with quote
Try looking in the current CCS C Manual under Standard String Functions on page 266.
There you will find a function that searches for one string in another.
For example usage you can simply Google on that function and you will find a lot of examples
PostPosted: Sun Jan 16, 2011 10:40 am     Reply with quote
There is also the question, of 'where is the string coming from'?.
If (for example), the long string is arriving from a source like the serial, then a state machine, may be a much more efficient 'algorithm'
What you do, is test each incoming character as it arrives, against the first character in the 'search' string (state 0). If this is seen, you advance to state one. State one, tests the arriving character against the next required value. If a good match, it moves to state two. If a failure, it moves back to state 0, and tries again. Similarly for each character in the incoming data.
Basically, there is normally only one test for each incoming character, and when the 'state' reaches the number of characters you are looking for, the required pattern has been seen.
'Walking' through a test pattern as data arrives, gives better efficiency in general, but at the cost of complexity. YPYMATYC.
gpsmikey
PostPosted: Sun Jan 16, 2011 1:12 pm     Reply with quote
"YPYMATYC" ???? Google only finds something similar that is a pesticide. Hadn't heard that one before ... YMMV
mikey
mikey
PostPosted: Sun Jan 16, 2011 1:57 pm     Reply with quote
You Pays Your Money And Takes Your Choice/Chance.
gpsmikey
PostPosted: Sun Jan 16, 2011 2:14 pm     Reply with quote
:-) Thanks !!
mikey
mikey
djsb
PostPosted: Sun Jan 30, 2011 7:59 am     Reply with quote
I'm trying to extract \n , \f and \b from a serial character stream sent from a PC to a 16f628A using the USART module. I need to extract the escape sequence's as I'm trying to send clear screen, backspace and newline commands to an LCD using Flex_LCD.C. Can someone expand for me on the state machine algorithm. Any examples I can use to get me started.
I've got the characters echoing to the LCD without problems, just need to be able to send \n etc and have this recognised as a command.
Any help appreciated. Thanks.
bkamen
PostPosted: Sun Jan 30, 2011 9:18 am     Reply with quote
Should have them add it here:
http://www.cygwin.com/acronyms/
