ahliang530
Please help for ADC voltage measurement |
Posted: Tue Jan 18, 2011 4:25 am |
I have no problem when compiling but I face error when I simulate in the proteus simulation. Once I click start button it show 3 errors:
1. ADC conversion started before 'wait' time has expired following previous conversion or channel change.
2. PORTA<0> is not configured as an analog input.
3. Voltage references for ADC conversion yield a 0V range.
But the simulation still running smoothly with show all the thing I wish to be done. I have not yet download to my PIC and try but I hope I can solve this problem b4 i try on it to avoid PIC damage.
Below is the link for my simulation photo (so sorry that I not really know how to show photo in the forum).
Thanks for helping
#include <16F877A.h>
#device ADC=12
#use delay(clock=10000000)
#include <LCDDRIVER.c>
float analin, disvolts, current;
int limit=0 , i ,d ,s;
SET_TRIS_C(0xFF);
SET_TRIS_A(0xFF);
SETUP_ADC_PORTS(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_8);
i = input(PIN_C0);
d = input(PIN_C1);
s = input(PIN_C2);
lcd_putc("\f");
if(s==1)
printf(lcd_putc,"Key in limit A:%d",limit);
if(i==0)
limit++;
else if(d==0)
limit--;
else if ( s == 0)
SET_ADC_CHANNEL(1);
analin = read_adc();
disvolts = (analin)/204.6;
current = (disvolts*240);
if ( disvolts >= limit)
lcd_putc("\f");
printf(lcd_putc,"voltage over:%d",limit);
lcd_putc("\n");
printf(lcd_putc,"voltage now:%1.4f",disvolts);
OUTPUT_HIGH(PIN_B1);
OUTPUT_HIGH(PIN_B2);
lcd_putc("\f");
http://flic.kr/p/9bcfn4 |
Posted: Tue Jan 18, 2011 6:34 am |
Well, your program is a good example as to why I never use Proteus !!
First, it should never have compiled as line two is wrong.
hint: read the ADC section of the PIC datasheet.
Second, as you area novice, get rid of the TRIS() statements and let the compiler take care of creating the correct code.
Third, you should fully 'setup' the PIC by disabling any internal peripherals that you are not using. This includes comparators, ADC pins, I2C, etc.
Fourth, it looks like you're running the lcd_init function inside the 'forever' loop.
It only needs to be called once, at the beginning of main but before the forever loop.
I create a 'setupPIC()' function, which defines pins,enable/disable peripherals, and calls 'one time' setups (like your LCD_INIT), as well as clears/sets I/O pins to my defaults. This setupPIC() function is then executed once, at the top of Main, before the forever loop.
Also be aware that floating point math uses a LOT of memory! Replacing it with integer math with really improve overall speed and use of memory.
hope this helps |
ahliang530
Posted: Tue Jan 18, 2011 7:14 am |
temtronic wrote: | Well, your program is a good example as to why I never use Proteus !!
First , it should never have compiled as line two is wrong.
hint: read the ADC section of the PIC datasheet..
Third, you should fully 'setup' the PIC by disabling any internal peripherals that you are not using.This includes comparators,ADC pins,I2C,etc.
I create a 'setupPIC()' function, which defines pins,enable/disable peripherals, and calls 'one time' setups(like your LCD_INIT),as well as clears/sets I/O pins to my defaults. This setupPIC() function is then executed once,at the top of Main, before the forever loop.
hope this helps |
what wrong with my line 2 statement that u mention, can u tell me?
may i ignore the TRIS and let the compiler determine itself?
can u please give me some further example for setupPIC function as u mention ?
last question .. is that mean i can proceed to download my code and ignore the error without damage my PIC ? |
Posted: Tue Jan 18, 2011 7:42 am |
Rather than telling you the answer to the ADC question, YOU need to learn
how to research these things yourself. Read Page 127 of the datasheet.
How many bits resolution is the ADC? _________________ Google and Forum Search are some of your best tools!!!! |
ahliang530
Posted: Tue Jan 18, 2011 8:13 am |
dyeatman wrote: | Rather than telling you the answer to the ADC question, YOU need to learn
How many bits resolution is the ADC? |
i get what u means .. thanks for your advice
so is that TRIS statement i can just skip it?
and then can i download my code into my PIC with those error (my budget is limited.. so i am worry for PIC damage) |
Posted: Tue Jan 18, 2011 9:21 am |
It is basically impossible to harm a PIC with code.
It is what you connect externally to it, that can do harm:
Supplies reversed.
Connections to pins carrying voltages outside the ratings.
Induced voltages throwing 'back' through the chip (when switching things like inductors).
Connecting loads without thinking about the currents they may draw (LED's without load resistors for example).
Obviously, beyond this, if you have external circuitry that if turned 'on' in the wrong pattern could cause problems (an H bridge for example), which you then turn on both the 'highside', and 'lowside' transistor at the same time. However unlikely to hurt the PIC, unless something else blows up, and shorts power through the PIC....
Yes, basically with CCS, _unless_ you are doing something where you specifically 'need' to override the default behaviour, for 90+ % of code, you can just ignore TRIS, and let the compiler handle it.
Now remember that the ADC input, is a capacitor, and understand why you need to wait after connecting it to a voltage, before taking the reading.
Gabriel
Posted: Tue Jan 18, 2011 9:40 am |
Another thing you might want to add is a small delay (~10ms) between these lines:
Code: | SET_ADC_CHANNEL(1);
analin = read_adc(); |
you need to allow some time for the sample and hold capacitor to charge.
else you will get wrong reads...
... just my two cents..
hope that helps..
G
Edit: i just noticed somebody already pointed this out... _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ahliang530
Posted: Wed Jan 19, 2011 7:01 am |
Gabriel wrote: | Another thing you might want to add is a small delay (~10ms) between these lines:
hope that helps..
G
Edit: i just noticed somebody already pointed this out... |
thanks for your advice .. i will try it out on my PIC .. |
Posted: Wed Jan 19, 2011 8:47 am |
hay Ttelmah
You can actually have a PIC survive the 'reversed power pins ' error....
...at least if it's only in backwards for 5-6 seconds ! |
Posted: Wed Jan 19, 2011 9:17 am |
and if the supply is current limited....
gpsmikey
Posted: Wed Jan 19, 2011 11:27 am |
"The most expensive component will always blow first to protect the fuse" or words to that effect
mikey _________________ mikey
ahliang530
Posted: Sun Jan 23, 2011 10:33 am |
hope this helps |
I try on my board .. but its not working
the LCD show a raw of dark box with showing ntg ...
I need HELP :( |
Posted: Sun Jan 23, 2011 10:59 am |
You seem to call lcdinit() several times???
I only call mine once, in the 'startup routine', after the code to setup the peripherals,variables,etc.
It'll be easier to debug if..
You create a new program just to test the LCD.
The classic 'Hello World' program.
That way you can verify the LCD runs properly.
Start off with small programs, build on what you learn and keep backups !
oh, and you still have #device adc=12 which is NOT correct and must be fixed. |
ahliang530
Posted: Sun Jan 23, 2011 12:08 pm |
temtronic wrote: | You seem to call lcdinit() several times???
Code: | #include <16F877A.h>
delay_ms(10);
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,"Hi, Milo 520");
my code is just simple as this .. but its not working ..
frustrated :( |
Posted: Sun Jan 23, 2011 12:15 pm |
Usually you have 'setup' or 'configuration' code before 'main', to tell the compiler what the I/O pins are to be used for,disabling interrupts,configuring onboard perihpherals,etc..
Since you haven't defined any I/O pins, perhaps there's a problem with the LCDDRIVER.C that you're using. |
