Error/Bug in == and != operators in 4.117 compiler on 24F?
GregReadUK
PostPosted: Mon Jan 24, 2011 4:43 am     Reply with quote
Hi Folks.
I am encountering a major problem in the latest compiler version 4.117. The != and == operators don't work as expected, e.g. 0 != 0.
Only tested on DEVICE:PIC24FJ64GA004
COMPILER VERSION:4.117
Can anyone offer any advice, see code example below.
Many Thanks,
Greg
#include <24FJ64GA004.h>
#device *=16
/* DEBUG FUSES THAT CAUSE VERIFICATION ERROR */
//#fuses DEBUG
//#device icd=true
#fuses NOWDT
#fuses ICSP1
#fuses NOWRT
#fuses NOPROTECT
#fuses NOJTAG
#fuses NOCKSFSM // NO FAIL SAFE CLOCK MONITOR
#fuses OSCIO   // OSC 2 IS A GENERAL PURPOSE INPUT
#fuses NOIESO   // THIS CAUSES IT TO BOOT OFF THE INTERNAL CRYSTAL IF EXTERNAL FAILED
//#fuses IESO
#fuses HS       // USE EXTERNAL HIGH SPEED OSCILLATOR
#fuses PR       // RUN OSCILLATOR AT HS OSCILLATOR SPEED
//   #use delay(clock=22118400)
#use delay(clock=25M)
// I2C definition for clock
//#USE I2C(MASTER, I2C1, FORCE_HW, RESTART_WDT)
#USE I2C(MASTER, SCL=PIN_B6, SDA=PIN_B5, RESTART_WDT)
#use rs232(baud=115200,parity=N,bits=8,errors,XMIT=PIN_B8,RCV=PIN_B13)
void Debug_putc(BYTE Data)
   putc(Data);
unsigned int8 ui1 = 0;
unsigned int8 ui2 = 0;
   int8 si1 = 0;
   int8 si2 = 0;
   unsigned int8 lui1 = 0;
   unsigned int8 lui2 = 0;
   unsigned int16 ui161 = 0;
   unsigned int16 ui162 = 0;
   unsigned int32 ui321 = 0;
   unsigned int32 ui322 = 0;
   printf(Debug_putc, "\r\nWhat are the != and == operators doing?\r\n");
   printf(Debug_putc, "DEVICE:%s\r\n", getenv("DEVICE"));
   printf(Debug_putc, "COMPILER VERSION:%s\r\n", getenv("VERSION_STRING"));
   if (ui1 != ui2)
      printf(Debug_putc, "ui1(%u) != ui2(%u)\r\n", ui1, ui2);
      printf(Debug_putc, "ui1(%u) == ui2(%u)\r\n", ui1, ui2);
   if (ui1 == ui2)
   if (si1 != si2)
      printf(Debug_putc, "si1(%u) != si2(%u)\r\n", si1, si2);
      printf(Debug_putc, "si1(%u) == si2(%u)\r\n", si1, si2);
   if (lui1 != lui2)
      printf(Debug_putc, "lui1(%u) != lui2(%u)\r\n", lui1, lui2);
      printf(Debug_putc, "lui1(%u) == lui2(%u)\r\n", lui1, lui2);
   if (ui161 != ui162)
      printf(Debug_putc, "ui161(%u) != ui162(%u)\r\n", ui161, ui162);
      printf(Debug_putc, "ui161(%u) == ui162(%u)\r\n", ui161, ui162);
   if (ui321 != ui322)
      printf(Debug_putc, "ui321(%u) != ui322(%u)\r\n", ui321, ui322);
      printf(Debug_putc, "ui321(%u) == ui322(%u)\r\n", ui321, ui322);
// Output produced -- Fails for 32bit, 16 bit and 8 bit ints
// What are the != and == operators doing?
// DEVICE:PIC24FJ64GA004
// COMPILER VERSION:4.117
// ui1(0) != ui2(0)
// ui1(0) != ui2(0)
// si1(0) != si2(0)
// lui1(0) != lui2(0)
// ui161(0) != ui162(0)
// ui321(0) != ui322(0)
GregReadUK
Fixed in 4.118
PostPosted: Mon Jan 24, 2011 4:58 am     Reply with quote
Just tried 4.118 and it is fixed. thanks.
Results are now..
COMPILER VERSION:4.118
ui1(0) == ui2(0)
ui1(0) == ui2(0)
si1(0) == si2(0)
lui1(0) == lui2(0)
ui161(0) == ui162(0)
ui321(0) == ui322(0)
PostPosted: Mon Jan 24, 2011 8:48 am     Reply with quote
Good, unfortunately there are sufficient unfixed bugs, like below, new in V4.114, reported Nov 01, 2010
http://www.ccsinfo.com/forum/viewtopic.php?t=44256
Or a double bug, reported 7 month ago, still present in V4.118
#include <24FJ128GA106.h>
#use delay(clock=16000000,RESTART_WDT)
#use rs232(UART1,baud=38400,parity=N,bits=8)
#case
   typedef struct {
     unsigned int8 b1,b2,b3,b4;
   } BS, *PBS;
   unsigned int32 mm = 16;
   unsigned int32 nn = 1024;
   BS bs = {1,2,3,4};
   PBS pbs = &bs;
void sub1(void)
   mm += nn/256;  // Wrong result due to register overwrite
0024A:  MOV.B   805,W0L
0024C:  MOV.B   806,W0L
0024E:  MOV.B   W0L,1
00250:  MOV.B   807,W0L
00252:  MOV     W0,W1
00254:  CLR.B   3
00256:  ADD     800
00258:  MOV     W1,W0
0025A:  ADDC    802,W0
0025C:  MOV     W0,802
   mm *= pbs->b3;
0025E:  MOV     #2,W0
00260:  ADD     808,W0
00262:  MOV     W0,W4
00264:  MOV.B   [W4],W0L
00266:  MOV     802,W1
00268:  MOV.B   W0L,W2L
0026A:  CLR.B   5
0026C:  MOV     #0,W3
0026E:  MOV     [--W15],W0 // Stack-Error
00270:  CALL    200
00274:  MOV     W0,800
00276:  MOV     W1,802
   sub1();
   while (1);
