PIC PIC16F877 -> PIC12f683
Goto page 1, 2  Next
thaking
PostPosted: Sat Jan 22, 2011 5:39 pm     Reply with quote
I want to make code of PIC16F877 working on PIC12f683. The code of PIC16F877 is working fine, but I need on PIC12f683. Can anyone help me with this:
I started with change in this code, but get several error's. I don't know why I can't use definition as in PIC16f877 #bit ..... in PIC12f683
#include <12F683.h>
..... see below
thaking
PostPosted: Sat Jan 22, 2011 6:14 pm     Reply with quote
Anyone? I really need fast help.
Many thanks
PostPosted: Sat Jan 22, 2011 6:20 pm     Reply with quote
One problem you have
#define nok_cs PIN_A3
PIN_A3 aka GP3 is an INPUT ONLY pin !! You cannot use it as the nok_cs control pin .
Page 2 of the PIC12F683 datasheet clearly shows this. You'll have to use another pin if possible, or use another PIC for your project.
thaking
PostPosted: Sun Jan 23, 2011 5:40 am     Reply with quote
@temtronic I correct this, but not working
I tried my code on proteus: NOT WORKING, ON SCREEN MUST BE "TEST1.....but's is not"
Any ideas?
My code is now:
#device PIC12F683
#use delay(clock=4000000)       // setup for internal 4mghz oscillator
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                    //Master Clear pin used for I/O
#FUSES PUT                      //Power Up Timer
PostPosted: Sun Jan 23, 2011 6:31 am     Reply with quote
With almost 40 years of programming micros(25 with PICs) I've learned that NO simulator works like the REAL World.
Sorry, but I do not use Proteus (or any other simulator). They do NOT work like real parts in the real world.All are full of 'bugs'!
You don't say what errors you get from Proteus(probably none),but I suspect the simulator is NOT telling you the truth.
Since you said this code worked fine with another part( I am assuming a REAL part, NOT the simulation), it might be in the 'configuration' or setup not the 'main' program that has the error.
I suggest creating a simple 'blinking LED' and program a real chip to confirm that you have the correct fuses etc.
Once you have a real LED blinking, rebuild your Nokia main code with your known good 'setup' code.Burn a real chip and see what happens.
thaking
PostPosted: Sun Jan 23, 2011 6:53 am     Reply with quote
@temtronic Proteus work fine, I tested on other code, with same PIC and 3310 just other code(example), so it must be problem in C code.
Maybe in configuration of PIN's wrong in my code, I don't know, so I asked you...
PostPosted: Sun Jan 23, 2011 7:27 am     Reply with quote
Couple of issues....
You're not using 'normal' PCM files...
IE: the normal pic12f683.h file for one thing.
From that file...
// Constants used to identify pins in the above are:
#define PIN_A0 40
#define PIN_A1 41
#define PIN_A2 42
#define PIN_A3 43
#define PIN_A4 44
#define PIN_A5 45
are the defines for the pins on PortA, for the 12f683
You've got this configuration...
#bit nok_dc = 0x40.0 //PIN_A0
#bit nok_res = 0x41.1 //PIN_A1
#bit nok_cs = 0x42.2 //PIN_A3
#bit nok_sda = 0x44.4 //PIN_A4
#bit nok_sclk = 0x45.5 //PIN_A5
only 1 might be right !
I'm NOT surprised that Proteus didn't list a LOT of errors, but it appears to me that your #bit assignments are pointing to RAM locations, NOT the actual PORTA pins.
That simple LED test I talked about earlier would have shown that out very quickly.
You can of course 'relabel' them for your use
also the use of the TRIS() function is best not used, let PCM handle that.
thaking
PostPosted: Sun Jan 23, 2011 7:39 am     Reply with quote
From that file...
#define PIN_A0 40
#define PIN_A1 41
#define PIN_A2 42
#define PIN_A3 43
#define PIN_A4 44
#define PIN_A5 45
Well I know that, but why in code of PIC16f877 was:
#byte portb=0x06
#byte trisb=0x86
#bit nok_sclk = portb.5    // RB5
#bit nok_sda  = portb.6    // RB6
#bit nok_dc   = portb.7    // RB7
#bit nok_cs   = portb.0    // RB0
#bit nok_res  = portb.1    // RB1
#byte tris_lcd = trisb
If I used for example:
#define PIN_A0 nok_dc
CCS will give me error's..
for example:
nok_dc=1;
because I need bytes...
PostPosted: Sun Jan 23, 2011 7:59 am     Reply with quote
look at your assignments for those pins
which worked
each bit assignment references one bit of portb ( RB5.5,RB5.6,etc.)
now look at what you did here
which do not work as you expect
0x40...0x45 are RAM locations,not PORTA
In the CCS manual it tells about this pin assignments..
Every PIC has a header that 'predefines' these values
your..
is backwards
#define nok_dc PIN_A0
is the corrrect way
this allows PIN_A0 to be referred to as nok_dc in your program
Every project I create, I include the PICpart.h file then 'reassign' the pins with new 'names' for that project,any unused pins have names like unusedA0,unusedB3, etc.
That way it's easy to see what available pins I have for future uses.
thaking
PostPosted: Sun Jan 23, 2011 8:06 am     Reply with quote
@temtronic thanks I understand what I do wrong, I define just location :X
But how can I define for example PIN_A0 as bit, like in PIC16F877 code? If I define for example #define nok_dc PIN_A0 , then will be error in code, because I need bytes; nok_cs=1; ..
PostPosted: Sun Jan 23, 2011 8:25 am     Reply with quote
Ok..
In the manual there's an article on how and why those numbers are used.
The COMPILER takes this information and does the 'bit assignments' automatically for you.Saves you a lot of headaches and you can rename them anytime you want.
example..
this is thePIC16F88.h file
#define PIN_A0 40
#define PIN_A1 41
#define PIN_A2 42
#define PIN_A3 43
#define PIN_A4 44
#define PIN_A5 45
#define PIN_A6 46
#define PIN_A7 47
#define PIN_B0 48
#define PIN_B1 49
#define PIN_B2 50
#define PIN_B3 51
#define PIN_B4 52
#define PIN_B5 53
#define PIN_B6 54
#define PIN_B7 55
in my program I 'redefine' as follows...
//defines for PIC16F88
#define nua7 PIN_A7
#define nua6 PIN_A6
#define nua5 PIN_A5
#define nua4 PIN_A4
#define nua3 PIN_A3
#define tsrt PIN_A2
#define tslt PIN_A1
#define nua0 PIN_A0
#define nub7 PIN_B7
#define nub6 PIN_B6
#define topc PIN_B5
#define GLED PIN_B4
#define FAN PIN_B3
#define nub2 PIN_B2
#define nub1 PIN_B1
#define nub0 PIN_B0
//defines for pinouts
As shown PIN_B3 has been given the 'name' FAN, so that any reference in the program will use it.
Ie. output_high(FAN) is the same as output_high(PORT_B3)
For me, any 'nuxx' define is an unused pin, available for future use.
The define 'GLED' refers to a Green LED, currently 'assignerd' to PIN_B4.
I tend to use short,equal length names.A habit from days when variables could only be a few bytes long.
thaking
PostPosted: Sun Jan 23, 2011 8:46 am     Reply with quote
@temtronic thanks for your time and help, buy you don't understand me what is my problem.
I will show now in PIC16F877 code which is work OK:
Original "configuration" of pin in working code are:
#device PIC16F877
#byte portb=0x06
#byte trisb=0x86
When I changed this in form which is usually normal for PIN configuration:
#include<16F877.h>
#byte portb=0x06
#byte trisb=0x86
#define nok_sclk PIN_B5
#define nok_sda PIN_B6
#define nok_dc  PIN_B7
#define nok_cs PIN_B0
#define nok_res PIN_B1
CCS compiler give's error. The same error is when I tried configure PIN's in PIC12f683 and THIS is my problem from beginning. I hope you will now understand me
Question
PostPosted: Sun Jan 23, 2011 9:14 am     Reply with quote
Do you still have
#device PIC16F877
as your first line ?
program should look like this...
#device PIC16f877
#include<16F877.h>
The .jpg was fuzzy, but I think the error is 'unrecognized identifier' which ,means the compiler has no knowledge of the 'word'.
Open up the 16f877.h file and see that the defines for the port pins are all there. Also there is a 16f877a.h version and you should use that if you're using the 16f877a chip.
thaking
PostPosted: Sun Jan 23, 2011 9:26 am     Reply with quote
Please look at my whole project(I have all set up, as you said; other code is the same as in original which work ok; but when I configure PIN's like you suggest CCS compiler give's me error's)
http://rapidshare.com/files/4443337/project.rar
Many thanks
PostPosted: Sun Jan 23, 2011 10:18 am     Reply with quote
You are a little like the guy putting diesel in a petrol car, then being surprised at problems....
You need to understand what you are doing.
There are a number of fundamentally different 'ways' of addressing pins in CCS. The CCS way, is to let the compiler do it's work, use the headers that come with the compiler, and then use the input, and output instructions.
Advantages:
1) Makes it far easier to transport code between processors.
2) Allows the compiler to control TRIS for you (for 99% of code, this is easier).
3) Generally more reliable.
However, it means you _must_ use the input and output instructions. You cannot access the port as if it was a register.
The alternative is to define the ports yourself.
Now your header, says you have used the latter, _which is why the CCS defines will not work for you_.
You need to do exactly what you did on the original processor, put back the original #bit defines (just changing the one used for CS), and then _editing_ the _port, and tris_ defines only, to match the data sheet of the new chip.
Goto page 1, 2  Next
Page 1 of 2
