lokken
Basic Read/Write Operation at SPI module |
Posted: Tue Jan 25, 2011 1:46 am |
I want to use SPI module of PIC 18f14k50. And first of all I wrote basic read/write commands for testing but I didn't achieve. My aim is sending a byte (data=15) with SPI module of 18f14k50. But I see wrong value at the serial port monitor. My compiler verison is 4.114. My codes:
Master
#include <18f14k50.h>
#include <PIC18f14k50_registers.h>
#FUSES NOWDT,XT,NOPUT,NOBROWNOUT,NOLVP,NOCPD,NOMCLR
int16 timeout;
int temp,data;
data=21;
TRISC=0x00;
TRISB=0b00110000;
sspcon1=0b00100000;
sspstat=0b00100000;
temp=SSPBUF;
SSPBUF=data;
while(!BF&&timeout<5000){
delay_us(1);
timeout++;
timeout=0;
temp=SSPBUF;
SLAVE
#use rs232(baud=9600, xmit=PIN_B7,rcv=PIN_B5)
int16 timeout;
int temp,data;
TRISB=0b01110000;
TRISC=0x00;
SSPCON1=0b00100101;
SSPSTAT=0b01000000;
temp=SSPBUF;
data=SSPBUF;
delay_us(1);
timeout++;
timeout=0;
printf("%d\r",data);
I just want basic read/write operation in SPI modes. Could you propose anything? I tried same codes for PIC16f877 and it is worked but I couldn't do it for 18f14k50.
Thanks |
Posted: Tue Jan 25, 2011 3:03 pm |
I don't know why you are writing directly to registers. I tested the
setup_spi() and spi_write() functions with vs. 4.114 and they work OK.
I see pulses on SDO (pin C7) and SCK (pin B6). Here is the test program:
#include <18F14K50.H>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP, CPUDIV1
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);
spi_write(0x33);
delay_us(100);
This thread has an example of an SPI Master/Slave program for two PICs:
http://www.ccsinfo.com/forum/viewtopic.php?t=39145
Here's an SPI slave test program for a single PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=26888 |
