about Timer0,1,2 for PIC16F877
nut7546
PostPosted: Thu Jan 20, 2011 3:00 am     Reply with quote
From below code.
Have value of A,B,C are equal?
#include <16F877A.h>
#include <stdlib.h>                                         //library for input.c
#define ADDR_DS1307  0xD0                                   //Address DS1307
#use I2C(master, sda=PIN_C4, scl=PIN_C3)                    //I2C Bus module
#include <lcd.c>
volatile unsigned int32 I=0,A=0,J=0,B=0,K=0,C=0,;
#INT_TIMER0
void Timer0_isr() {
   if(I++>3) {
   A++;
   output_toggle(PIN_A0);
   I = 0;
#INT_TIMER1
void Timer1_isr() {
   if(J++>0) {
   B++;
   output_toggle(PIN_A1);
   J = 0;
#INT_TIMER2
void Timer2_isr() {
   if(K++>0) {
   C++;
   output_toggle(PIN_A2);
   K = 0;
   set_tris_b(0xFF);//port RB4 and RB5 input only
   set_tris_d(0x00) ;  //portd output only
   set_tris_a(0x00) ;
   lcd_init();
   enable_interrupts (GLOBAL);
   enable_interrupts (INT_TIMER0);
   enable_interrupts (INT_TIMER1);
   enable_interrupts (INT_TIMER2);
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64);
   set_timer0(0);
   output_low(PIN_A0);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   set_timer1(0);
   output_low(PIN_A1);
   setup_timer_2(T2_DIV_BY_16,0XFF,15);
   set_timer2(0);
   output_low(PIN_A2);
   while (true)
