PS 2 controller using UART
iamintel
PostPosted: Wed Jan 19, 2011 2:51 pm     Reply with quote
Hi
I'm programming PIC16F877A to send and receive data via UART using this device I just bought from cytron
http://www.cytron.com.my/usr_attachment/SKPS%20User%20Manual.pdf please refer to the manual
but still no luck programming it.
For now, I just try to program one button (p_square) to switch LED (portb7) on/off and from the manual the host(PIC) need to send data to the device and the device return value=0(if pressed).
I did some programs, but none of them worked Sad
Below is my code:
#include <16f877a.h>
#fuses hs, noprotect, nowdt, nolvp
#use rs232(baud=9600 ,xmit=PIN_C6,rcv=PIN_C7, parity=N, ERRORS)//rs232 settings
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
int get_data , send_data;
#define   p_select      0// in decimal
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define   p_l2         8
#define   p_r2         9
#define p_l1         10
#define p_r1         11
#define p_triangle      12
#define p_circle      13
#define p_cross         14
#define   p_square      15
#define p_joy_lx      16
#define   p_joy_ly      17
#define p_joy_rx      18
#define p_joy_ry      19
#define p_joy_lu      20
#define p_joy_ld      21
#define p_joy_ll      22
#define p_joy_lr      23
#define p_joy_ru      24
#define p_joy_rd      25
#define p_joy_rl      26
#define p_joy_rr      27
//serial interrupt
#int_rda
 RDA_isr()
    if(kbhit())
      putc(send_data);
      get_data = getch();
   // set i/o
   set_tris_a(0xff);
   set_tris_b(0x02);
   set_tris_c(0xff);
   setup_port_a(NO_ANALOGS);
   setup_timer_2(T2_DIV_BY_16, 100, 1);
   set_rtcc(0);
   setup_counters(RTCC_INTERNAL, RTCC_DIV_1);
   enable_interrupts(INT_RTCC);
   //set serial interrupt
   enable_interrupts(int_rda);
do
if(send_data =15) // press  p_square button
  if (get_data==0)
       output_low(pin_b7); //Led Off
       delay_ms(50);
  output_high(pin_b7);//Led On
  delay_ms(50);
  }while(1);
Will some of you guys look at this code and help me out
