How to setup_comparator() in PIC16F917 (mechatronic board)
newpic
PostPosted: Tue Jan 18, 2011 1:00 pm     Reply with quote
I am trying to get the CCS work on the mechatronic board. I am following the example project using CCS. I am working on project2.
I am stuck on the comparator setup.
The hardware setup / connection as follows:
Light sensor - RA0
POT1 - RA3
LED - RD7
The main idea is to light up LED when light sensor < POT1
Can anybody explain the following? What do they mean? Which is the right one for me to use? (I got this straight from my device.h file).
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparator() are:
#define NC_NC_NC_NC  0x00FF07
#define NC_NC  0x00FF07
#define A0_A3_A1_A2  0x30FF04
#define A0_VR_A1_VR  0x30FF02
#define A3_VR_A2_VR  0x30FF0A
#define A0_A2_A1_A2  0x30FF03
#define A0_A2_A1_A2_OUT_ON_A4_A5  0x00CF06
#define NC_NC_C1_C0_OUT_ON_A5  0x00DF05
#define NC_NC_A1_06_OUT_ON_A5  0x00DF0D
#define A3_A2_A1_A2  0x30FF09
Here is my code, it does not do anything when run it.
#include <16F917.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT
#use delay(clock=8000000)
#define LED   PIN_D7
#byte LEDPORT = 0x08
main()
   ////////////////////////////////////////////////////////////////// I/O
   // Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
   //                         PORT_B_PULLUPS(), INPUT(),
   //                         OUTPUT_LOW(), OUTPUT_HIGH(),
   //                         OUTPUT_FLOAT(), OUTPUT_BIT()
   // Constants used to identify pins in the above are:
   SET_TRIS_A(0x05);
   SET_TRIS_D(0x00);
   Setup_comparator(A0_A3_A1_A2 | COMP_INVERT);
   // Constants used in setup_vref() are:
   setup_vref(VREF_LOW | 5); // Vref = 5v * (5/24) = 1.04v
   // Wait for the Comparator mode change delay, and the Vref
   // settling time. (spec = 10 us, so use 20us to be safe).
   delay_us(20);
   // Continuously poll the Comparator output status bit.
   // If it's high, it means the input voltage is greater
   // than the Vref voltage.  In that case, turn on the LED.
   // If not, turn the LED off.
         if(C1OUT == 1)
         output_high(LED);
         output_low(LED);
        delay_ms(100);   // Debounce time
Please help.
Thanks.
PostPosted: Tue Jan 18, 2011 1:54 pm     Reply with quote
Post a link to the website for this board.
newpic
PostPosted: Tue Jan 18, 2011 3:34 pm     Reply with quote
Here is the link to the the board.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023837
newpic
PostPosted: Tue Jan 18, 2011 3:38 pm     Reply with quote
In case the previous link does not work.
Here is any the pdf version
http://ww1.microchip.com/downloads/en/DeviceDoc/51568a.pdf
PostPosted: Tue Jan 18, 2011 4:19 pm     Reply with quote
If you install the Mechatronics project files and look at the .ASM source
code for Project2, you can see that they load register CMCON0 with 0x14.
; Configure comparators
  movlw  b'00010100'  ; 0x14
  movwf  CMCON0       ; Turn comparators on as two
                      ; independent comparators,
                      ; invert C1 output
To duplicate this same setup with CCS, make a test program, choose
some likely parameters and look at the .LST file to see if you did it
correctly. Here is the test program:
#include <16F917.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT
setup_comparator(A0_A3_A1_A2 | COMP_INVERT);
Here is part of the .LST file (compiled with CCS compiler vs. 4.116).
It loads CMCON0 with 0x14, so it matches the .ASM example code.
You can use this setup in your CCS program.
......... setup_comparator(A0_A3_A1_A2 | COMP_INVERT);
001C:  CLRF   CMCON1
001D:  MOVLW  14
001E:  MOVWF  CMCON0
001F:  MOVF   TRISA,W
0020:  IORLW  30
0021:  MOVWF  TRISA
0022:  MOVLW  03
0023:  MOVWF  @77
0024:  DECFSZ @77,F
0025:  GOTO   024
0026:  MOVF   CMCON0,W
0027:  BCF    STATUS.RP0
0028:  BCF    PIR2.C1IF
newpic
PostPosted: Tue Jan 18, 2011 6:46 pm     Reply with quote
So I got it right, why my program does not do anything?
PostPosted: Tue Jan 18, 2011 7:14 pm     Reply with quote
What is your CCS compiler version ?
newpic
PostPosted: Tue Jan 18, 2011 7:35 pm     Reply with quote
PCM 3.249
newpic
PostPosted: Tue Jan 18, 2011 8:16 pm     Reply with quote
run your test program and here is what I get
.................... setup_comparator(A0_A3_A1_A2 | COMP_INVERT);
001E:  CLRF   17
001F:  MOVLW  14
0020:  MOVWF  1C
0021:  MOVF   05,W
0022:  IORLW  30
0023:  MOVWF  05
0024:  MOVLW  06
0025:  MOVWF  77
0026:  DECFSZ 77,F
0027:  GOTO   026
0028:  NOP
0029:  MOVF   1C,W
002A:  BCF    03.5
002B:  BCF    0D.5
PostPosted: Tue Jan 18, 2011 9:05 pm     Reply with quote
SET_TRIS_A(0x05);
SET_TRIS_D(0x00);
The TRIS that you have set for PortA is incorrect. That's why it doesn't work. You have pin A3 set an output, but it needs to be an input since
it goes to the comparator.
But, you don't need to set the TRIS. The compiler will do it for you.
That's one of the most useful (but least known - CCS doesn't advertise it)
features of CCS. Just delete both those lines and let the compiler handle
the TRIS.
newpic
PostPosted: Tue Jan 18, 2011 9:32 pm     Reply with quote
Thank you. It works.
