pfsdanny
cannot display characters using lcd.h and usb_cdc.h (solved) |
Posted: Mon Jan 17, 2011 12:37 am |
Here is my code
tester01.h :-
#FUSES BORV19
#FUSES HFOFST
#FUSES USBDIV2
#FUSES PLLEN
#FUSES BBSIZ1K //1K words Boot Block size
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES PCLKEN
#FUSES NODEBUG //Debug mode for use with ICD
#use delay(clock=12000000)
#use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=8) |
tester01.c :-
#include <tester01.h>
#define LCD_ENABLE_PIN PIN_C6
#define LCD_RS_PIN PIN_C4
#define LCD_RW_PIN PIN_C5
#define LCD_DATA4 PIN_C0
#define LCD_DATA5 PIN_C1
#define LCD_DATA6 PIN_C2
#define LCD_DATA7 PIN_C3
#include <lcd.c>
#include <usb_cdc.h>
#use fast_io(b)
#use fast_io(c)
output_high(UARTREQUEST);
set_tris_b(0b00110000);
set_tris_c(0b10000000);
usb_init_cs();
setup_adc_ports(sAN9|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
//TODO: User Code
lcd_putc("\fHello");
while (true) {
The lcd display just show blocks not characters. When I remark the #include <usb_cdc.h> and usb_init_cs() the display is ok. Is there somthing wrong with my code?
I have compiled another program to test the usb function and it works ok.
Danny |
pfsdanny
memory too large |
Posted: Mon Jan 17, 2011 4:02 am |
I just modify the statement
From
struct commProp {
unsigned int8 count;
unsigned int8 size;
unsigned int8 buffer[20];
} uart, usb; |
To
struct commProp {
unsigned int8 size;
unsigned int8 buffer[17];
} uart, usb; |
Although the CCS reported that I have available memory, but the LCD does not display anything when the buffer size is larger than 17. Does not know whether this is a compiler bug or not. |
