Create do re mi with 16f887 using 8Mhz crystal
derricko
PostPosted: Mon Nov 22, 2010 4:21 am     Reply with quote
const int s_table[] = {128,176,218,246,255,246,218,176,
                            128,79,37,9,0,9,37,79};
static int t0preload,frequency=150;
#int_timer2
void pwm_load(void) {
   setup_ccp1(CCP_PWM);
    set_pwm1_duty(s_table[s_tableidx++ % 8]);
   set_timer2(t0preload);
main()
        t0preload = 100;//256 - (62500 / frequency);
   setup_timer_2(T2_DIV_BY_4,frequency,1);
       blah blah....
I try to create a code as modified from
http://www.ccsinfo.com/forum/viewtopic.php?t=36540
I try to work out a code to generate a good Do Re Mi Tone for my project.
It doesn't seem to work well, the tone generated is generally some kind of noise with 2 tones. I have no idea what I have done wrong. Guess my knowledge on timer with PWM is very limited. Quite confused with the frequency component as stated in the thread.... Anybody can help? Appreciated. Crying or Very sad
PostPosted: Wed Nov 24, 2010 3:29 pm     Reply with quote
Try modifying the CCS example file, Ex_Tones.c and the driver file for it, tones.c.
I did this. I edited the Ex_tones.c file and removed the data for their
"Happy Birthday" music. I added the DoReMi notes. It works.
These are the changes I made above main():
#define SIZE 8
const struct
long tone;
long length;
}doremi[] = {
C_note[0], 400
D_note[0], 400,
E_note[0], 400,
F_note[0], 400,
G_note[0], 400,
A_note[0], 400,
B_note[0], 400,
C_note[1], 800  // Use next higher octave for last note
In main(), I edited the code in the for() loop to use the 'doremi' data:
 generate_tone(doremi[i].tone, doremi[i].length);
In the Tones.c file, I changed the output pin to be Pin C2, because my
PicDem2-Plus board has a beeper on pin C2:
#define TONE_PIN  PIN_C2
To make it work with an 8 MHz crystal, edit the #use delay() statement
so it has 8 MHz in it:
#include <16F877.h>
#use delay(clock=8000000)
derricko
PostPosted: Sun Nov 28, 2010 7:33 pm     Reply with quote
Thank you PCM, I will give a try Very Happy
gpsmikey
PostPosted: Sun Jan 16, 2011 1:31 pm     Reply with quote
In looking at the PicDem2-Plus board schematics, I see they are creating sort of a fake "H drive" to the Piezo buzzer" but with their configuration, there is always a DC voltage applied to the piezo element. In reading the spec sheets for a number of them, it indicates you should not have a DC bias on the piezo element. Has this been a problem for those with the PicDem board or does it seem to work just fine ?
mikey
mikey
