Change in compiler behaviour between v4.114 and v4.116
EdWaugh
PostPosted: Tue Jan 04, 2011 10:12 am     Reply with quote
Hi all,
I’m having a problem with v4.116, it is behaving differently (and giving the wrong result) for some code that worked fine under v4.114 (and previous versions). I’m not sure if the C I have written is strictly legal tho (and there are certainly other ways to achieve the same result).
What I am doing is referencing a byte inside a 32 bit value (data), I wanted something portable and I prefer to avoid doing math on pointers so that’s why I use the [] referencing to increment through the values.
v4.114
....................    uint8_t a = ((uint8_t*)&data)[0];
05F30:  MOVLW  0B
05F32:  MOVWF  FEA
05F34:  MOVLW  8C
05F36:  MOVWF  FE9
05F38:  MOVFF  FEF,B94
05F3C:  MOVLB  B
....................    uint8_t a = make8(data, 0);
05F30:  MOVLB  B
05F32:  MOVFF  B8C,B94
v4.116
05F30:  MOVLW  0B
05F32:  MOVLB  B
05F34:  MOVWF  x96
05F36:  MOVLW  8C
05F38:  MOVWF  FE9
05F3A:  MOVFF  B96,FEA
05F3E:  MOVFF  FEF,B94
05F30:  MOVLB  B
The make8() function is much more efficient either way though so I should just change to that.
Any suggestions, especially on the validity of my C statement would be most welcome.
ed
PostPosted: Tue Jan 04, 2011 12:50 pm     Reply with quote
Post a compilable test program that displays the results with a printf
statement. Then we can drop it into MPLAB and run it in MPSIM
and see if it works.
The test program needs to have the #include for the PIC, #fuses,
#use delay, typedef statement(s), variable declarations, main(), etc.
FvM
PostPosted: Tue Jan 04, 2011 1:17 pm     Reply with quote
Your code is valid, but ineffective under CCS C, as you already mentioned.
The V4.116 code is mainly introducing an unneccesary step. But the result should be correct, as least it is in my test with MPLAB SIM. If you also check other indices than 0, you realize that V4.116 is getting completely confused, blowing up the code size by 120%. But the result is still correct.
V4.112:
....................  a = ((unsigned int8*)&data)[1];
0870:  MOVLW  02
0872:  MOVWF  FEA
0874:  MOVLW  1B
0876:  MOVWF  FE9
0878:  MOVFF  FEF,219
V4.116:
0874:  MOVLW  02
0876:  MOVWF  x24
0878:  MOVLW  1A
087A:  MOVWF  x23
087C:  MOVLW  01
087E:  ADDWF  x23,W
0880:  MOVWF  FE9
0882:  MOVLW  00
0884:  ADDWFC x24,W
0886:  MOVWF  FEA
0888:  MOVFF  FEF,219
Which surprizes will be brought by V4.117?
PostPosted: Tue Jan 04, 2011 4:05 pm     Reply with quote
Or just use a union, which is portable to non CCS compilers, and as efficient as make8...
FvM
PostPosted: Wed Jan 05, 2011 3:40 am     Reply with quote
A union will be only efficient, if the source data type is already defined as a union, otherwise either a copy operation or a typecast by pointer, similar to the shown example would be necessary.
It would be interesting to know, if the shown long-winded interpretation of the typecast by pointer is a particluar CCS C problem, or if it can be found with other PIC compilers as well?
EdWaugh
PostPosted: Wed Jan 05, 2011 5:36 am     Reply with quote
Hi guys,
Thanks for the responses, it's nice to know I'm not completely crazy.
Shouldn't the compiler identify this operation for what it is? Why should the ASM be any longer than for the make8() function? All the inputs are constant.
I also emailed this to CCS as a bug, I'll report back if I get a response.
Cheers
Ed
FvM
PostPosted: Wed Jan 05, 2011 6:49 am     Reply with quote
It would be fine, indeed. Apparently, the ability of CCS C to understand the meaning of some popular C constructs instead of decoding them literally, step-by-step, is somewhat limited. I guess, you'll find a similar behaviour with other embedded C compilers, too. Their big brothers, compilers like Microsoft or Borland C++ however don't have it.
EdWaugh
PostPosted: Wed Jan 05, 2011 7:31 am     Reply with quote
I was working a bit more with my code and realised that this change is making it not work in various other places as well. I don't really want to go around fixing legal C code that worked on previous versions. What are the chances CCS will fix this?
ed
FvM
PostPosted: Wed Jan 05, 2011 10:08 am     Reply with quote
I'm presently keeping V4.112, because PCD has an arithmetic bug in the newer versions up to V4.116 and I'm waiting for a fix. I reported it about two month ago, so hopefully it will be fixed in the next release. There are probably some changes related to the bug in V4.115, but it's still reproducible with the test code, I sent to CCS. Because the bug report hasn't been answered explicitely (except for the automated acknowledge mail), I can't be sure if it has been actually processed.
Most previously detected bugs are handled by workarounds in my code. You surely can imagine, that I'm not motivated to check which each new CCS release, if they have probably been fixed silently. I know, that many (or even most) actually have been fixed, but a few still exist, possibly modified.
Only if bug reports would be treated exactly and all changes to the compiler listed in detail, you could expect more.
PostPosted: Wed Jan 05, 2011 10:20 am     Reply with quote
You don't need to typecast by pointer. You can do a simple typecast. No data movement is needed.
union combine {
    int32 word32;
    int16 word16[2];
    int8 b[4];
    int32 value = 0x01020304;
    int8 small;
    small=((union combine)value).b[0];
    printf("%2x\n\r",small);
    ((union combine)value).word16[1]=0x0405;
    printf("%08Lx\n\r",value);
    while(TRUE);
Shows reading the first byte from an int32, and writing an int16, into the high half of the int32.
It really is efficient. For example, on the example above, with 'value' at 0x11, the byte move codes as:
....................     small=((union combine)value).b[0];
0056:  MOVF   11,W
0057:  MOVWF  15
//and the 16bit move, as:
....................     ((union combine)value).word16[1]=0x0405;
0063:  MOVLW  04
0064:  MOVWF  14
0065:  MOVLW  05
0066:  MOVWF  13
It is also portable (with the caveats about byte order on different processors), with the same code happily running under C on Unix, or on VC from MS....
FvM
PostPosted: Wed Jan 05, 2011 3:25 pm     Reply with quote
Yes, you're right. I've been using this construct before. Thanks for remembering.
typedef union
   signed int32 l;
   signed int8 b[4];
}lr;
 a = ((lr)data).b[1];
....................  a = ((lw)data).b[1];
08AA:  MOVFF  21B,219
EdWaugh
PostPosted: Mon Jan 17, 2011 9:49 am     Reply with quote
Hi all,
I got this response from CCS today:
This message is a reply to CCS e-mail id: 1AE002
I am not able to recreate with 4.117.  Resumbit this with your source code if you still have the problem with 4.117.
Not super helpful really but once 4.111 is available for download I'll let you know if it works.
cheers
ed
gpsmikey
PostPosted: Mon Jan 17, 2011 11:30 am     Reply with quote
At least you got a response from them. When I submitted a problem with the fact that they don't have the database correct for the 18f14k22, I got a response indicating it had been received and assigned to a tech. Last I heard from them. Hopefully 117 comes out before my upgrade period runs out end of this week :-) Have to see if they fixed mine too.
mikey
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
EdWaugh
Fixed
PostPosted: Sun Aug 14, 2011 5:24 am     Reply with quote
Sorry about the late follow up to this but the error was fixed by v4.121 and should now compile correctly.
I have just posted a new but similar bug in v4.124 here:
http://www.ccsinfo.com/forum/viewtopic.php?t=46082
Cheers
Ed
