BUG REPORT: 4.114
59seconds
BUG REPORT: 4.114
PostPosted: Thu Dec 30, 2010 9:42 pm     Reply with quote
Compiling for the 24fj256da210 (with or without debug set), will generate configuration words in the wrong locations (reversed order).
Way to reproduce:
Compile simple 'hello world' with various fuses set. Import this hex file into MPLAB and under the 'Configure' -> Configuration bits, you can clearly see that the fuses are set incorrectly.
A workaround is to edit the table of the device (editing of table only works when NODEBUG fuse set).
Config words should be reorganized in this order:
1->4
2->3
3->2
4->1
Not sure if this is fixed with latest 4.116. Table 27-1 in device datasheet shows correct config address locations.
EDIT: There could be more bugs, this is just the first one I found trying to get this part working. Currently I'm not even able to output anything on the UART, but I can toggle a pin.
PostPosted: Fri Dec 31, 2010 2:47 am     Reply with quote
Sorry for confusing the discussion. The below statement is wrong. The bug is in PCD, and it's fixed in V4.116.
I briefly checked the issue. Assuming the present PIC24FJ256DA210 datasheet is correct, then the bug is in MPLAB, not in CCS C. I use MPLAB V8.53.
I guess, you noticed that the addresses are reversed related to the configuration word numbering. Basically, 24FJ256DA210 uses the same configuration word layout as other PIC24 chips I'm using, e.g. PIC24FJ256GA110. I see, that the configuration is correctly set in the *.hex file. If I read the DA210 *.cof file to a GA110 configuration in MPLAB, the configuration words are assigned correctly. If I select DA210, they are wrong. May be a newer MPLAB version fixes the problem.
I'm not using the new PIC24 chip and don't feel a need to investigate further on this issue now. In any case, you should contact CCS.
59seconds
PostPosted: Fri Dec 31, 2010 9:33 am     Reply with quote
Thanks for verifying it. Do you know if 4.116 also fixes the UART? It's broke to high-heaven in 4.114. (with the da210 chip anyways).
PostPosted: Sat Jan 01, 2011 4:35 am     Reply with quote
I'm using V4.112 for my active projects, but it misses correct support of 24fj256da210. I didn't yet notice UART issues with V4.114 or V4.116. Can you post an example code that produces the problem?
59seconds
PostPosted: Mon Jan 03, 2011 10:29 am     Reply with quote
Well Gosh dog it... it's working now, but I promise something funny was going on last week. After I solved the config word problem, I started on the Uart problem, and over the weekend I told myself to check that 0x8400 being written to the U1MODE (The '4' is a non-location, or perhaps even reserved). I also noticed you have to use UART1A in the #use rs232(*) or else it'll not use Uart1.
I've got some more boards to bring up. I see if I can reproduce the error.
59seconds
PostPosted: Mon Jan 03, 2011 11:36 am     Reply with quote
O.k., I figured out what is breaking the UART. Whenever a delay is used, it never gets past the delay.
#include <24FJ256DA210.h>
#FUSES NOWRT
#FUSES noDEBUG                  // Debug mode for ICD
#FUSES ICSP3                    //ICD uses PGC3/PGD3
#FUSES pr
#FUSES xt
#FUSES NOCKSNOFSM //CKSNOFSM
#FUSES NOIESO
#use delay(clock=8000000)
#include <string.h>
#pin_select u1tx=PIN_f4
#pin_select u1rx=PIN_d15
#use rs232(uart1a,baud=9600,parity=N,bits=8)
            delay_ms(50); //<<--  Uses a delay in any place in the code causes UART to break.
            printf("b");  //never gets here
PostPosted: Mon Jan 03, 2011 4:35 pm     Reply with quote
MPLAB SIM executes the code correctly, when compiled with V4.116. If it's not working in the real hardware, you should trace the execution with a debugger.
