Could I use CCS for LF (+3.3v) version?
FMOpt2000
PostPosted: Tue Sep 27, 2011 4:59 am     Reply with quote
Hi. In the CCS it's listed the PIC18F4525 but not the lower voltage version the PIC18LF4525.
Could I use the Wizard with 18F4525 for the LF version?
Or Do I need to choose only the PIC in CCS with LF specifically showed?
Thx in advance.
Frank.
PostPosted: Tue Sep 27, 2011 5:40 am     Reply with quote
The only difference 'should' be the operating voltage, so I say yes.
Simple test, cut 'hello world' code, compile, program the PIC and add battery. If it works then you KNOW it works.
