adalucio
pic stop working during float division? |
Posted: Sat May 14, 2011 9:18 am |
Hi. I have got a pic16f876 (clock 20MHz). I need to count pulses on rb4 and rb5 and do some calculations.
When arrives too many pulses the pic stop working. why?
#include <main.h>
#include "flex_lcd_16x2.c"
unsigned int16 cicliA = 0;
float portataA = 0;
unsigned int16 cicliB = 0;
float portataB = 0;
#int_RB
void detect_rb_change()
int current;
static int last = 0;
set_tris_b(0xF0);
current = input_b();
if((!bit_test(last,4))&&(bit_test(current,4)))
cicliA++;
else if((!bit_test(last,5))&&(bit_test(current,5)))
cicliB++;
last = current;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
delay_ms(600);
printf(lcd_putc, "\f");
enable_interrupts(INT_RB);
portataA = (float) cicliA / (7.5);
portataB = (float) cicliB / (7.5);
lcd_gotoxy(1,1);
printf(lcd_putc, "A: l/min: %lf ", portataA);
lcd_gotoxy(1,2);
printf(lcd_putc, "B: l/min: %lf ", portataB);
cicliA = cicliB = 0;
Posted: Sat May 14, 2011 1:39 pm |
Quote: | When arrives too many pulses the pic stop working. why? |
Describe the pulses. What is the repetition rate of the pulses ? What is
the pulse length ? Is it the same pulse length for all pulses ?
What are the voltage levels (high and low) of the pulses ?
What specifically does this mean ? Does it mean the display is not updated ? |
adalucio
Posted: Wed May 18, 2011 1:57 am |
Solved with this code. thanks
#include <main.h>
float portataA = 0;
float portataB = 0;
#int_RB
int current;
set_tris_b(0xF0);
cicliA++;
cicliB++;
last = current;
setup_adc(ADC_OFF);
delay_ms(600);
disable_interrupts(INT_RB);
disable_interrupts(GLOBAL);
lcd_gotoxy(1,1);
lcd_gotoxy(1,2);
Posted: Wed May 18, 2011 2:58 am |
and the reason is, that the pulses are coming in faster than the arithmetic can be handled (hence PCM programmers questions about rate....).
