16F676 vs 16F684
arunkish
16F676 vs 16F684
PostPosted: Tue Jan 04, 2011 6:32 am     Reply with quote
Hi
Wish you all a happy new year. I have been reading ADC with 16F676 without any problem. I migrated to new controller 16F684 and used the same code to read the ADC. I am getting a value that is nearly 200 times higher than what I get in 16F676. setting #deivce adc=8 did not help. Is there anything that I should do more to make it work with 16F684.
Thanks & Regards
arunkish
PostPosted: Tue Jan 04, 2011 6:44 am     Reply with quote
Sorry forgot to tell how I had setup things..
in main:
setup_adc_ports(sAN0);
void readadc(void)
    int value;
   set_adc_channel(0);
   delay_ms(5);
                value=read_adc();
PostPosted: Tue Jan 04, 2011 1:08 pm     Reply with quote
void readadc(void)
int value;
set_adc_channel(0);
delay_ms(5);
value=read_adc();
The internal ADC clock is not recommended for normal use by the
16F684 data sheet. Look in the following section of the data sheet:
9.1.4 CONVERSION CLOCK
TABLE 9-1: ADC CLOCK PERIOD (TAD) VS. DEVICE OPERATING FREQUENCIES (VDD > 3.0V)
It shows the recommended ADC clock divisor to use for each PIC
oscillator frequency. For example, if you have a 4 MHz crystal, then
use Fosc/8. The CCS constant for this is ADC_CLOCK_DIV_8.
For 8 MHz oscillator, use ADC_CLOCK_DIV_16, etc. Look in the table
in the data sheet.
If that doesn't solve your problem, then post a small compilable test
program and post your compiler version.
Also post a description of the external circuit which is connected to the
A/D input of your PIC.
