		| Author | Message |
		| msilvar
				| Help with fprintf and STDOUT |
				|  Posted: Thu Jan 06, 2011 8:08 pm |   |
				| Hello,
 I'm working in a code that uses two USART, one in SW and the another in HW. Everything was going smooth until the last build returned an error:
  	  | Quote: |  	  | *** Error 132 "C:\Microchip Solutions\Lauca Eth\A08001000MU\Main_C.c" Line 319(21,22): STDOUT not defined (may be missing #USE RS232)  ::
 1 Errors,  0 Warnings.
 I'm looking if I make a mistake but my code is in the same state that the last debug session with the ports working. The #use rs232 are there and have this syntax:
  	  | Code: |  	  | #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=Lauca,errors)
 #use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B0,bits=8,stream=RS485,errors)
 Is this a failure of my IDE software (MPLAB & CCS) or there could be anything else?
 Here are the main portions of my code:
  	  | Code: |  	  |
 #OPT 9
 #include <16F883.h>
 #device *=16
 #device adc=10
 #FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
 #FUSES PUT                      //Power Up Timer
 #FUSES NOMCLR                   //Master Clear pin enabled
 #FUSES NOPROTECT                //Code protected from reading
 #FUSES NOBROWNOUT               //No Reset when brownout detected
 #FUSES NOIESO                   //Internal External Switch Over mode disabled
 #FUSES NOFCMEN                  //Fail-safe clock monitor disabled
 #FUSES NOLVP                    //No low voltage prgming
 #use delay(clock=8000000)
 #use FAST_IO(C)
 #use FAST_IO(B)
 #use FAST_IO(A)
 //Headers
 #include <string.h>
 #include <stdlib.h>
 #include <A08.h>
 void TXUsart()
 disable_interrupts(INT_RDA);
 fprintf(Lauca,"Hello");  //Test
 fputc(0x0A,Lauca);
 fputc(0x0D,Lauca);
 fputc(Trama_comm.NodoID[0],Lauca);
 fputc(Trama_comm.Comando[0],Lauca);
 fputc(Trama_comm.Puerto[0],Lauca);
 fputc(Trama_comm.DatoRCVL[0],Lauca);
 fputc(Trama_comm.DatoRCVH[0],Lauca);
 fputc(0x0A,Lauca);
 fputc(0x0D,Lauca);
 clear_interrupt(INT_RDA);
 Any help will be useful.
 Thanks in advance
		| msilvar
				|  Posted: Thu Jan 06, 2011 8:20 pm |   |
				| Hey folks, I found the issue.
 In a header I have defined three vars as follows:
  	  | Code: |  	  | //****************************************************************
 //Port Mapping, Addresses and Commands
 //#define Lauca      0x00         //Lauca Address
 //#define HMI         0x0A      //HMI Address
 //#define A08         0xFF      //A08 Address
 #define ReadPort   1u         //Read Port
 #define ReadData   2u         //Read Data
 #define ReadStat   3u         //Read Status
 #define ReadConf   4u         //Read Config
 I've commented the first three and everything was solved. But the doubt is still there. Whats happened? What was my mistake? (I'm sorry if my question is idiot, but I'm not clear with what was the mistake).
		| gpsmikey
				|  Posted: Thu Jan 06, 2011 9:31 pm |   |
				| You can't have a stream name with the same name as something else - this came up recently, but I don't remember the exact context.  (in this case, you named the stream "Lauca" but also had a #define for it as 0x00
 mikey
 mikey
 | You cannot post new topics in this forum You cannot reply to topics in this forum
