ICD2 with CCS
Bilal
ICD2 with CCS
PostPosted: Mon Mar 07, 2011 3:47 am     Reply with quote
Hi. I am using ccs compiler 4.093 and I am using ICD2 with this.
It work well with debugging.
The problem is I am unable to use ICD2 as a Programmer.
Every time it connects it start debugging.
Please help.
PostPosted: Mon Mar 07, 2011 3:02 pm     Reply with quote
According to this thread, the Microchip ICD2 can only be used for
debugging with the CCS IDE (PCWH, etc.), and not as a programmer:
http://www.ccsinfo.com/forum/viewtopic.php?t=33186
Bilal
PostPosted: Tue Mar 08, 2011 1:50 am     Reply with quote
is there any way to use ICD2 as a programmer in CCS
Bilal
PostPosted: Tue Mar 08, 2011 2:13 am     Reply with quote
http://www.ccsinfo.com/newsdesk_info.php?newsdesk_id=86
in this page it is mention that we can switch b/w debugger to programmer..
any one please help
PostPosted: Tue Mar 08, 2011 2:57 am     Reply with quote
If so, ask CCS how it goes. For the time being, you may want to use Microchip MPLAB for programming. You also get a great simulator and a means to check CCS fuses settings against the manufacturer specification. It's useful in case of doubt.
Bilal
PostPosted: Wed Mar 09, 2011 4:01 am     Reply with quote
anyone has its solution please.. i want to use ICD2 as a programmer in CCS.. as mention in this page..
if it is not possible then why they are mentioning it in this official page..
