sorasit46
| How to write code for convert 2,B,C --> 2BC ? |
Posted: Sat Dec 11, 2010 8:37 pm |
2,B,C = Hex. Value ( Dec. = 700 )
regards |
gpsmikey
Posted: Sat Dec 11, 2010 9:17 pm |
Assuming you mean you have those characters in a buffer of some sort, see the functions atoi(), atol() and atoi32() in the compiler manual - they convert a null terminated string into a number.
mikey _________________ mikey
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Sun Dec 12, 2010 2:40 am |
atoi, atol and atoi32 all require a "0x" in the buffer to decode hex data. That might be OK, maybe not...
strtol/strtoul support a radix argument.
Or, you can do the conversion yourself. It helps to break the problem down into two steps:
1. Convert ASCII character to number: | Code: | if (c >= 'A' && c <= 'F') v = c - 'A' + 10;
if (c >= '0' && c <= '9') v = c - '0'; | 2. Accumulate numbers into a total:How to handle invalid characters is up to you. The above is just an example. _________________ Andrew |
gpsmikey
Posted: Sun Dec 12, 2010 5:31 am |
Well, I'm glad to see Andrew was more awake than I was - I started looking for scanf() and realized we don't have that. His approach is probably the best unless you want to create a buffer with "0x" in it then append the character string. You also may want to consider how to handle a backspace
for example if these numbers are being entered from a keyboard.
sorasit46
Posted: Sun Dec 12, 2010 9:46 am |
| Thanks for the help! |
