write a 64K xmodem file to a 24c512 using i2c on a PIC16F690
antiwingates
PostPosted: Thu Dec 09, 2010 11:13 am     Reply with quote
Hi folks.
I am not able to do a full write of a 64KB .bin file of a 24c512 i2c eeprom using a XMODEM 128 protocol.
Write work fine until 0x2000h (8192bytes) address, the pic hang-up.
If i comment the 4 lines with write_ext_eeprom the file is received fine, but of course isn't write.
here is the code:
void receive(void)
  byte c=0,a=0;
  if(rxchar<3)//SOH + BLOQ + C-1
       buffer1[rxchar]=getc();
  if ((rxchar>=3) && (rxchar<35))
       buffer2[rxchar-3]=getc();
  if ((rxchar>=35) && (rxchar<67))
       buffer3[rxchar-35]=getc();
  if ((rxchar>=67) && (rxchar<99))
       buffer4[rxchar-67]=getc();
  if ((rxchar>=99) && (rxchar<131))
       buffer5[rxchar-99]=getc();
  if (rxchar==131)
      chk=getc();
  rxchar++;
  switch (buffer1[0]) {
            case SOH:
                 if (rxchar>131) // we have whole frame
                    c=~buffer1[1];
                    if (buffer1[2]==c) //checksum of no.frame correct
                      for (c=0;c<32;c++)
                      {                              a+=buffer2[c];
                        a+=buffer3[c];
                        a+=buffer4[c];
                        a+=buffer5[c];
                      if(a==chk)   //Checksum data correct
                         for (c=0;c<32;c++)
               write_ext_eeprom(page+c, buffer2[c]);
                            write_ext_eeprom(page+c+32, buffer3[c]);
                            write_ext_eeprom(page+c+64, buffer4[c]);
                            write_ext_eeprom(page+c+96, buffer5[c]);
            page+=128; //pages of buffers
                         rxchar=0;  //Number of bytes of the frame
                         putc(ACK);
                         putc(NAK); //retransmit frame chksum error
                    }//chk.frame correct
                       putc(NAK);  //retransmit frame header error
            case EOT:
               putc(ACK);
               rx=0;
            case CAN:
               putc(ACK);
any idea???
PostPosted: Thu Dec 09, 2010 1:11 pm     Reply with quote
Since you say that it works 'fine' for the first 8KB then ...
Off the top of my head, I'd say the function write_ext_eeprom is limited to 8KB, perhaps a 'page' worth of data.
Would have to look at it in detail to see though.
