how to implement strstr between ram and rom strings (SOLVED)
ambokyo
PostPosted: Wed Dec 01, 2010 8:01 am     Reply with quote
I'm trying to port a code I made in Hitech C to CCSC
if (strstr(SerialBuff, "stringtofind") != 0)
Above code is workingin hitech c. SerialBuff is a string received from uart.
When I compile, I get the following error
Attempt to create a pointer to a constant
So how do I convert the above code or what is the equivalent code in CCSC?
Wayne_
PostPosted: Wed Dec 01, 2010 8:03 am     Reply with quote
Try #device PASS_STRINGS=IN_RAM
ambokyo
PostPosted: Wed Dec 01, 2010 8:14 am     Reply with quote
Wow!, the error disappeared!
Thank you so much.
